Frosted paint colors? How are they done?
Old Jul 8, 2004 | 07:34 PM
primarycolorman's Avatar
I've seen one or two cars around town that appear, for lack of a better word, 'frosted'. I'd assume its something done to the clearcoat and was wondering if anyone knew anything more or had samples of it..
Was thinking a frosted cobalt or electron blue would look great on a SS..
Old Jul 8, 2004 | 07:50 PM
AW/whiteZ-28's Avatar
Try to find a pic that looks like the paint I dunno what you are talking about
Old Jul 8, 2004 | 07:58 PM
Dark Angel's Avatar
Or is it a pearl coat?
Old Jul 8, 2004 | 08:14 PM
JoeliusZ28's Avatar
you mean like somebody waxed their car without wiping it down
Old Jul 8, 2004 | 08:28 PM
none of the above gents. Definitely not primer, and i doubt its perl unless there is a matte version of it.
I'll keep searching, maybe I can turn up an example.
Old Jul 8, 2004 | 08:45 PM
Eh, no luck.
Ok, try #2 for describing it.
It looked something akin to a matte anodized finish, except it had more depth and had a slightly hazy/milky tint over it. Maybe it was a pearl, but I can't say that I've seen a matte pearl before..
It might be a screw up from a local shop for all I know.
Old Jul 9, 2004 | 09:37 PM
notstock4long's Avatar
A pearl coat is not really at all like a 'frosted' finish. You could have a red pearl color, and that is really pretty normal. The pearl part just means that it has flakes in it, kind of like metallic paint. I am pretty sure it's only called that because they used to use real pearls for the flakes. But now I am pretty sure they just use plastic flakes.
Old Jul 10, 2004 | 07:27 AM
97FormulaWS-6's Avatar
Originally posted by crazyjim
Pearl is a material that reflects light (like metallic) but also allows some of the light to pass though and reflect back from the surface below. The light reflected may be un-obstructed, or may pass through another particle of pearl, adding the illusion of depth, and altering the hue. Paints containing pearls usually contain a higher resin to pigment ratio and require more coats of material to obtain full coverage. The newer tri-coat systems involve a base coat, a clear/tint coat, and a final clear coat. This creates a very nice effect, but makes spot repair more difficult.
Exactly... That's wy the paint job that I'm gettin on my car is going to be a pain if anything ever happens afterwards... I'm using 1 base color (The stock red) and 3 different Pearls... A red right ontop of the base-coat, a white over that, and then Silver stripes done only in pearl, with atleast 3-5 clear coats over the whole thing. It's nice to have family in the business..
May 1, 2015 01:14 PM
k1996z28
Apr 13, 2015 06:54 PM
Jubjub
Mar 19, 2015 10:23 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
