Front license plate holder removal
Old Mar 28, 2003 | 08:22 PM
StrungZ's Avatar
I went to remove it but it is glued on and didnt want to hurt the bumper. How do i remove it without damage to the bumper?
Old Mar 28, 2003 | 10:19 PM
Ernster500's Avatar
Re: Front license plate holder removal
Take the license plate off first.
Then get a long screw driver with a torx bit (can't remember what size) and put it down each of the two holes in the bracket. Take out each screw, and it will come right off.
The only problem will be two big gapping holes in the front of the grill!
E
Old Mar 28, 2003 | 11:06 PM
AW/whiteZ-28's Avatar
Red face
Mine are thorx screws the * ones that might be it too
Old Mar 28, 2003 | 11:16 PM
Ernster500's Avatar
Oh yeah, that's right!
Old Mar 28, 2003 | 11:56 PM
Z28-CTYHNTR's Avatar
I dont know about which method yours is attached to the grille. But mines was riveted on Anyway, I used a relatively small drill bit and trilled out the cores of the rivets, being extra careful not to go all the way through into the fasica. Then I ripped that sucker off, have 3 holes in the grille but Im getting a billet soon anyway.
Old Mar 29, 2003 | 12:52 PM
StrungZ's Avatar
I took the license plate off and looked at those two holes, but no screws were in there. I believe there was threads but it seems to be glued on. Any ideas?
Old Mar 29, 2003 | 06:21 PM
Originally posted by StrungZ
Any ideas?
Nope
Old Mar 29, 2003 | 08:12 PM
Brent94Z's Avatar
Super Moderator
Depends on how bad you want it off If it were mine and I really wanted it off, I'd just rip the damn thing off. If I damaged the paint, I'd have it fixed. Even if you do damage to it, I presume you'll only damage the black area between the fogs and if you want to get by really cheap, it shouldn't be too much to get just that fixed... it'll also fix the two holes that may be there as well
Old Mar 29, 2003 | 09:08 PM
OK you know you take the plate off right then, there is 2 holes in the holder in those holes are the thorx * screws take those out and that should be it
Find a pic of what you plate holder looks like so we know what your working with
Old Mar 29, 2003 | 10:17 PM
pmatch1's Avatar
Where the screws went in will be pulled up. You can drill this rough material off with a bit or cut it off flush with a blade. From your local store you can buy push in type fasteners. Black or coloured. Like the fasteners that hold your interior panels together, fender liners or hood insulaters. The head will be approx. 1/2" in. dia. They cover up the hole and give it a finished look.
Jun 6, 2015 08:27 AM
Brake_L8
Jan 20, 2015 09:44 AM
heavenly_six
Dec 10, 2014 12:23 AM
Z28STYLE23
Aug 17, 2002 07:40 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
