Fresh paint, tonneaus, lowered.
Old Mar 9, 2013 | 04:44 PM
Randy Bilyea's Avatar
Old Mar 9, 2013 | 05:58 PM
KYWes's Avatar
Re: Fresh paint, tonneaus, lowered.
Looks great! Mind giving details. Was it painted the same color? Did you need bodywork? How much did it run you? I have a 95Z I'm about to get painted.
Old Mar 10, 2013 | 07:36 AM
I pulled this from another forum, so a few people have probably seen it, but here is the build thread.
Total cost of body and paint: $2900
Total cost of lowering $850 - Eibach sportlines, KYB AGX's, mounts, links, PH bar.
Some pics of the before, during and after:
BEFORE:
LR fender:
Front bumper cover:
Scratches and Dents on hood:
Torn RF Fender skirt and bubbling on rocker:
Old Mar 10, 2013 | 07:38 AM
DURING:
Rear spoiler was in good shape, just one low spot
Left rocker only needed a small piece of steel, the fender lip was almost completely replaced:
Left side fender lip and under fuel door completely replaced with new steel:
Right side inner fender well replaced with new steel:
Right side rocker. That hole in the back of it he made while I was there. Lightest of taps with the body hammer, went right through. 2/3's of that rocker was replaced with new steel
New Steel in right side fender:
Plastic repair on torn right front fender skirt:
Right inner fender replaced with new steel:
Old Mar 10, 2013 | 07:41 AM
AFTER
So after some discussion with some paint experts, I went with the new Lexus "Starlight Mica Black" (0217) Essentially a black pearl metallic to replace the original GM 8555 black:
I'm waiting for it to get sunny so I can get some good pics of the flake in the paint, but this will give you an idea anyway:
Old Mar 10, 2013 | 07:43 AM
Eibach Sportlines Install:
Eibach sportlines and QA1 panhard bar.
We got the rears done on Saturday, after much screwing around with the drivers side bolt on the panhard bar, we eventually just cut the head off and drove the bolt through. It was seized in the bushing and we had to use the impact hammer to drive it through.
The rest of the rears was VERY easy. Undo the bottom shock bolt, lower the rear axle, and the springs pulled right out. Install new ones, bolt everything back up and it's done. Except for the links of course, I am picking them up this afternoon.
Rear spring comparison:
Fronts were another story altogether.
After breaking both sway bar links, we undid the upper ball joint, undid the bottom shock bolts, undid the top strut mount bolts, they pulled right out.
Only to find that the top nut on the shock was so badly rusted that it is impossible to get them out of the strut mounts.
New KYB AGX's & mounts ordered and installed.
This will successfully eliminate the rest of my upgrade budget for a long while....wife is getting VERY grumpy...:icon_slapcry:
Old Mar 10, 2013 | 12:04 PM
KYWes's Avatar
Thanks for posting here. It is interesting to see.
Old Mar 10, 2013 | 10:26 PM
bigz28man's Avatar
car looks great man, black is sexy
Old Mar 10, 2013 | 11:51 PM
FirebirdGT's Avatar
Are those Stainless Specialties oval tips?
Old Mar 11, 2013 | 05:07 AM
lymlyt96's Avatar
That is niiice nothin quite like a fresh paint job.
Old Mar 11, 2013 | 10:30 AM
No, they are S/S Ractive tips. The PO put them on when he did the cat-back system.
GREEN3112
Feb 10, 2019 09:19 PM
football4life
Oct 4, 2015 07:48 AM
CARiD
Sep 30, 2015 05:44 AM
DelSoto
Sep 19, 2015 05:31 AM
92_RS_305
Sep 8, 2015 07:47 PM
