Freedom design Wing HELP!!!
Old Sep 10, 2003 | 12:36 PM
CoUnTryMuZiCZ28's Avatar
I bought this freedom design wing from freedomdesign.com and its about 4 inches bigger than the RS if youd like the link here it is http://www.freedomdesign.com/Merchan...ry_Code=wings1 ..... I get to pick it up in about 2 hours and it will be painted.. the thing i need help on is how do i bolt it on with out drilling through the spoiler?? I dont want to drill through the bottom. the top is ok drilling through. I dont exactly feel good putting 3M double sided tape on it.... Does the spoiler on a 95 Z28 come apart, like does the part ontop of the 3rd brake light come apart from the part under the 3rd brake light? I havent taken it off the car just yet but i want to have this figured out before I mess with it. Once its off the car does it come apart anymore than it already is?? Please some one help me.. The spoiler by the way calls for 6 bolts to be place in the spoiler,2 in the center 2 on the far right and 2 on the far left..
Old Sep 10, 2003 | 01:06 PM
350 HRSS's Avatar
I am trying to understand what exactly you are asking. Does it say to apply it w/ 3M tape?
You mentioned drilling holes. Does it give locations? If you are not sure about this, why not let the shop install it. You don't want to make a mess out of it.
The stock spoiler on the Z is one piece. It comes off w/ a few bolts. the 3rd brake light just has 2 screws and it comes out.
You will probably have to drill. Those spoilers look good though
Let us know more info
Old Sep 10, 2003 | 03:41 PM
MiDnIGhTRiDE8's Avatar
i agree if ur not sure about the screws and what not i would have a shop do it.
but thats just my opinion
Old Sep 10, 2003 | 03:54 PM
Z95m6's Avatar
probably should of test fitted and installed it first before it was painted.
Old Sep 10, 2003 | 04:34 PM
The screws are already there in the spoiler.... I Cant get under the factory one to screw the screws in. It has to come apart into two peices... Im actually messing with it now..
Old Sep 10, 2003 | 08:49 PM
Kyle@CSS's Avatar
I have this spoier on my car. it comes with a template. it tells you were to drill the holes.
Old Sep 10, 2003 | 09:26 PM
Zeeya: I drilled all the holes and put it on already.. Will it come off if i only put the screws in.. no washers or nothing.. only screws. I put some of the ring things it came with under the spoiler so it wouldnt rattle(the foam things)..
Old Sep 10, 2003 | 09:27 PM
Old Sep 26, 2003 | 09:58 PM
Kyle@CSS's Avatar
Im sorry just got to this, It will be fine. If your scared use a little red locktight. Mines holding up fine.,
Henson071
Dec 30, 2015 09:55 PM
NewsBot
Sep 15, 2015 11:53 AM
karpetcm
Aug 14, 2015 03:02 PM
NewsBot
Aug 3, 2015 02:40 PM
