Finally! New Steering wheel is ON!
Once you buy the car, you can do whatever you want to it.
The only downside is that if my insurance company finds out, my insurance will go up
Originally posted by MadKilla
Sweet, did you get the horn working? If you did what did you do with the yellow airbag wire?
I removed the airbag clockspring and cut the yellow wire in half and removed the clockspring from the top and the plug/wires from the bottom.
I have 100% zero intentions of ever putting an airbag wheel back in this car so it was a very easy descision for me to simply remove that stuff.
I am glad you guys like it, I really do!
Originally posted by RCJim
The horn works, both thumb buttons are hooked up to it.
Where did ya pick the steering wheel puller up at?
Can you just use a universal puller, or u need a special one?
i need to pull mine off.... got some wires crunchin somewhere in there, along with the occasional short, and a nice red air bag warning light....
Originally posted by Ferocity02
Sell the airbag because you can get quite a bit of money from those things. To replace two airbags in a car costs in the thousands. Or just blow it up or something
The clockspring is the grey round piece behind the wheel with the two wires coming out correct? How did you get it off? I tried but mine wouldn't move. It has given me some problems too so be glad you took it off.
I just cut the wires coming out of the back and removed it, I then pulled the remaining part of the airbag wires out of the bottom of the column.
Just remember to disarm the airbag system before you work on it - You can refer to a Tech Manual for the proper steps.
No more airbag to blow up in my face. It sounds like your clockspring is attached differently than mine was, there was no C-clip on the shaft holding the clockspring. Either that or I am blind. Which is entirely possible, since I was incredibly eager to attach the Sparco wheel. By the way, you asked on another thread about the front end swap to an 98+. Everyone quoted you $1500, I did mine for $500. The difference for me was I waited a little more than 6 months to accumulate parts from junkyards, ebay, and this board. I even got all the parts already color matching because I was patient. It costs $1500 if you buy the parts in mass, from a dealer/f-body boneyard, and more if you have to paint it. There are tons of V6 wreckers that are NOT in f-body specialty junkyards.
carguyshu
Jan 22, 2017 11:19 AM
ro2207
Dec 4, 2014 06:18 PM
