Final Question About Rims
Old Feb 26, 2003 | 08:52 AM
Pure's Avatar
O.K.
I have an opportunity to purchase used rims.
The size of the rim is 18 x 8.5 in a 5 x 120mm bolt configuration with a 40mm offset.
Will these fit on my 98 Camaro
All help would be greatly appreciated
Pure
Old Feb 26, 2003 | 09:16 AM
TA25th's Avatar
And the answer is......YES, and they will fit very well.
They will fit in the wheelwell almost exactly like mine do here:
http://www.ls1.com/forums/showthread...=split+and+adr
Those on the front of my car are 18x8.5 5x120 and 38mm offset, so yours will fit almost exacly the same, just inset 2mm more than mine, which will be pretty much unnoticeable.
Shawn
Old Feb 26, 2003 | 09:36 AM
Pure's Avatar
Thank you for replying, however, my concern is that your 94 TA configuration is different from my 98 Camaro.
Just as a note, those rims look awesome
Pure
Old Feb 26, 2003 | 09:38 AM
TA25th's Avatar
Pure
Thanks, and TRUST me, those rims you want to buy WILL work....your setup is not that different from mine.
Shawn
Old Feb 26, 2003 | 01:27 PM
caspergotaz28's Avatar
The wheelwell area on the Camaro and Transam is identical. Under the body panels and interior, the cars are the same. The outer appearance of the fenders appear different but take a F-body down to it's unibody and you will have a hard time telling the difference between pontiac and chevy.
We wanna see pics when you get those 18's mounted up.
Old Feb 26, 2003 | 05:58 PM
KillerTA's Avatar
So, what kind of rims are they?
Sergio
Jan 27, 2016 04:27 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Kato
Jan 26, 2015 09:21 PM
ChrisFrez
Dec 7, 2014 06:01 PM
