Electrical... LED.. voltage help
Old Apr 18, 2003 | 02:45 AM
2_shady's Avatar
I just ordered a bunch of blue led's off ebay and want to install them whenever i get some free time.... However, i can not find the volt specifications for some of the lights i will be replacing... are all the light bulbs 12 volt?
in the:
door handles?
steering wheel controls?
light under the shifter plate?
please lemme know
thanks
Old Apr 18, 2003 | 03:19 AM
Severous01's Avatar
yes, they are all 12 volt. most take a 194 bulb replacement, and thats 12 volts and 22.5 watts
Severous01's Avatar
Old Apr 18, 2003 | 07:47 AM
97FormulaWS-6's Avatar
They're all 12V... the easiest way to install the LEDs in your car safely is just by hooking a 1K ohm resistor up to either lead of the LED then just hooking the + and - up and you're good to go. The resistor limits the current (amperage) that goes to the LED and keeps it from "poping"...
I actually poped a few last night on accident while building my new tail lights.... damn short in the circuitboard... I wasn't happy I blew 6 $1.50 LEDs.... But I got all of them built... now this weekend's project is to do the final assembly and get my car back together...
Old Apr 19, 2003 | 12:47 AM
2_shady's Avatar
I just put in 2 today.... they look great.. i swapped out those red lights on the door handles and put in an led.. i used 1 led and a 470 ohm resistor... had em in for a few hours and everything looks to be good
... 470 ohm is the correct resistor right? i used ohm's law to figure it out
Old Apr 19, 2003 | 02:21 AM
6Speed's Avatar
So this means if you put the LED bulbs in your blinkers, they are gonna pop?
I bought some for my brakelights (red 3157), and after I put one in, my fuse blew. Any correlation, or just a coincidence? They are made by APC, and said they are a replacement for 3157 bulbs.
Old Apr 19, 2003 | 11:19 AM
95m6's Avatar
No, by pop they mean that the actual led bulb will bust not your fuse.
If you had a fuse pop after putting them in that means they are drawing too much of a load for the fuse you have. Just go and buy some lower watt bulbs to fix this, but I would first try a new fuse and see if it does it again if so then go buy soem lower watt bubls.
RUENUF
Mar 13, 2016 03:37 PM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
Aug 7, 2015 01:26 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
