easy way to get these to shine?????
Old Dec 4, 2005 | 01:30 PM
amean94ta's Avatar
i have made wheels shine before but i want chrome like shine?
Old Dec 4, 2005 | 06:49 PM
Purplemaroz28's Avatar
Re: easy way to get these to shine?????
itll take a while but try some 800 grit sand paper, then move to 100 grit then finally 2000. If you spray surface Klean from dupont on the 2000 sandpaper youl get a deadly shine, this is what i used for the fuel rails, intake manifold, and brackets while my engine is out.
Old Dec 5, 2005 | 12:14 AM
mystic-t/a's Avatar
Try a Mothers power ball with the power polish.
http://www.autogeek.net/mokit.html
And get 20% off by using "maxthescrooge" for the discount code...shhh, I didn't tell you. lol
Old Dec 5, 2005 | 12:31 AM
luckyou03's Avatar
if you sand them.. go 800-1000-2000! Dont use 100 grit!!!
But I'm recommend trying that mother's powerball.
Old Dec 5, 2005 | 03:37 AM
mook99TA's Avatar
I agree stay away from 100 I think he meant 1000
Old Dec 6, 2005 | 12:00 PM
flusz28's Avatar
sand them down like those guys said. go to www.speedymetalpolish.com this is by far the best stuff. just one wipe across a stained polished metal like discolored brake lines. they shine like chrome in 5mins.... stuff is unreal. i made my ac lines and unit and fuel rails shine like glass without even sanding them. i sanded and poished my slotted/drilled rotors and they look like chrome and even after using the brakes they still look good 3,000miles later..
Old Dec 6, 2005 | 04:47 PM
amean94ta's Avatar
cool but dry or wet sand???
Old Dec 6, 2005 | 05:05 PM
flusz28's Avatar
everything i have ever polished i did it dry, you could also put a small amount of polish on the sand paper if you wanted. i then used a hand drill with a buffer wheel on the end,so i could give my arms a rest from buffing.
CARiD
Sep 30, 2015 05:44 AM
Fatdog2
Sep 16, 2015 11:04 PM
NewsBot
Sep 15, 2015 11:53 AM
Daluchman1974
Sep 11, 2015 06:12 AM
themex2002
Sep 2, 2015 03:47 PM
