drilling a real pool ball for shift knob
Old Feb 20, 2006 | 04:26 PM
69z-28's Avatar
drilling a real pool ball for shift ****
anyone know how i could do this? my dad thinks there has to be some way to put a plastic insert that is threaded in there how the stock ***** come but im thinking just drill it and tap it, but what would be the best way to drill a round ball? basically looking for anyone who has tried this and has succeeded.
Old Feb 20, 2006 | 06:21 PM
MiNuS-tWo's Avatar
Re: drilling a real pool ball for shift ****
you could try putting it in a vice and use a drill press. i have never found it easy to drill round objects.
Old Feb 20, 2006 | 07:50 PM
crasher88's Avatar
I agree with that just start with a very very very small bit and slowly work your way up to a bigger bit until its almost as big as shift pole and see if you can find a tap that is the save size and thred and see if you can tap the hole you drilled into the ball and see if it will screw on. Best advice I can give you on this matter.
Old Feb 20, 2006 | 07:56 PM
Camarocracy's Avatar
Or you could buy one http://www.thehotrodgirl.com/8ballshifter.html
Old Feb 20, 2006 | 08:39 PM
97FormulaWS-6's Avatar
Ok, first off take a dremel and cut through the outer spot and just create a divit; it'll make drilling a ton easier; this can be done with a file as well.
Then, just a drill-press and a vice, and head to town.
Then don't pull it out of the vice, and insert the threaded tube and JB Weld it in there.
That's how I've done pool-***** before; I've done 8-*****, 9-*****, Que-*****, and a 3-ball for a kid.
Old Feb 20, 2006 | 11:06 PM
69z-28's Avatar
hmmm. thanks for the advice. i think im just gonna haev to try it. i just ordered a brand new 8 ball from the local pool hall.lol. o well gotta try something. thanks for the help guys, ill keep everyone posted on how it goes.
camarocracy: i dont know if that will fit the fairly large stick that is used on these cars, but idk, thanks anyways.
Old Feb 21, 2006 | 12:50 AM
Daniel6718's Avatar
sand a flat spot...drill into that
Old Feb 21, 2006 | 12:29 PM
grandnational007's Avatar
i almost actually thought about selling these at one point....
very easy to make provided you have the right tools/access to machinery. (luckily, I work in a machine shop, so i do)
1: take ball
2:wrap in plastic wrap or other extremely malable shipping material (has to be slip resisitent, and so the surface doesn't get damaged)
3: sqeeuze it into the vice of a bridgeport.
4:using the SLOWEST speed, and a 3/8" end mill, sink it in
5:I forgot the thread size of a t-56, but after it's figured out, get 3/8" riv-nuts with the matching thread pattern, and insert riv-nut
6:voila!
made a few of these at work, mostly for people with hondas, but they worked fine none-the-less
Old Feb 21, 2006 | 12:43 PM
69z-28's Avatar
ive never heard of a rivnut before but i looked it up and i know what you mean. however where can i get them? home depot or something have them? thanks for the good advice.
Old Feb 21, 2006 | 01:45 PM
dreamer1q's Avatar
I had one in my S10 back in highschool....drilled it with a press and a small bit. had to rough the spot up a bit to get it to bite, and I used a Helicoil for the threads with some epoxy. Worked great.
Old Feb 24, 2006 | 09:04 AM
Critter's Avatar
best advice yet
Old Feb 24, 2006 | 10:40 AM
ibanez6rg's Avatar
Tap, then drill.
Old Feb 24, 2006 | 08:02 PM
PWR-TRIP's Avatar
Originally Posted by ibanez6rg
Tap, then drill.
I do that to my g/f almost everyday.
Old Feb 24, 2006 | 08:33 PM
Hawk's Avatar
me to
MyfateZ28
Oct 5, 2015 12:36 PM
willismoons
May 27, 2015 04:03 PM
PROJECT X
Apr 17, 2015 12:13 AM
Apr 16, 2015 09:57 AM
Jason Short
Jan 19, 2015 06:34 PM
