Does adding a bodykit affect E.Ts
Old Apr 23, 2003 | 01:12 PM
WrecklessZ's Avatar
I'm about to put a wings west bodykit on today. Will I feel a difference?
Old Apr 23, 2003 | 01:26 PM
caspergotaz28's Avatar
It seems if you add weight to the car, you're car will be slower.
But aerodynamically, it seems that less air would get under the car and instead go around it making you slip through the air better.
It would be an interesting experiment to make a bunch of runs with and without the body kit to see if there really is a signifigant difference.
EDIT: Whoo-hoo, 1500th post and I'm now a prominent member. A personal triumph
Old Apr 23, 2003 | 01:39 PM
AW/whiteZ-28's Avatar
You won't "feel" a difference but you might notice one in your times, might be bad or good go test it out for us
238 posts more for me till that status
Old Apr 23, 2003 | 01:59 PM
White Z 4 Show's Avatar
I was running a 9.30 consistantly before the kit and once I put the kit on I was running a 9.35. Then I added a few things and consistantly run a 9.1 or 9.2 now. If you only bolt it up, I think you won't notice much. But if you have it molded on like I did, you might lose some time. But .05 of a second was worth all the compliments I get about the kit. I'd do it again if I had to
Old Apr 23, 2003 | 02:57 PM
Bralgar's Avatar
Ooooo, how would you change the front fenders if the need ever arose?
Old Apr 23, 2003 | 03:22 PM
iamsparc's Avatar
Talking
Cut and paste, baby....cut and paste
-Mike
Old Apr 23, 2003 | 03:33 PM
Arrow
I think he probably only molded the nose and not the side-skirts.
Old Apr 23, 2003 | 03:55 PM
chesee48's Avatar
Originally posted by caspergotaz28
[B]It seems if you add weight to the car, you're car will be slower.
Agreed, thats with adding any suspension stuff too...
But, the GFX are hella lite, buy like u said..aerodynamically, it will be less air under the car. Esp. with the WW gfx that has a bigger front gfx and the longer air dam. Thats why i went with a kit that used a smaller front and used the stock air dam. I also added the "home-made ram air" that will help conpensate any loss of air with the gfx...
Old Apr 23, 2003 | 06:52 PM
pu12en12g's Avatar
Yes you will be so slow you will run home from the track crying.
j / k
It will make LITTLE if ANY difference....
Old Apr 23, 2003 | 09:30 PM
95 Mystic TA's Avatar
Re: Does adding a bodykit affect E.Ts
I would love to hear the replies from a few rice boys.
Oh hell yeah y0, you could probably dust one of those new tight Vett's wit it
Not a flame on you, just on the rice boy mentality. Good question actually.
Old Apr 24, 2003 | 09:22 AM
I have all 4 WingsWest body pieces molded on. Front, sides, and the rear. All are molded on. Oh, and still holded up strong
Old Apr 24, 2003 | 10:17 AM
MonoxideChild's Avatar
E/t's in Sig
made little or no difference at all.
Old Apr 24, 2003 | 10:31 AM
pu12en12g's Avatar
Originally posted by MonoxideChild
E/t's in Sig
Twiztid Fan ?
Old Apr 24, 2003 | 02:00 PM
jg95z28's Avatar
If you stick a huge wing on the back of a Honda, does that make it faster?
I hope that answers your question.
Old Apr 24, 2003 | 02:15 PM
2nd2none's Avatar
Remeber when TransAms and Formulas gave diffrent times? The guys at Road and Track said that the Higher topspeed on the TransAm 157mph was becuz of the ground effects, giving the car better aero dynamics, but the reason the Formula was quicker on 0 to 60 was becuz of the lack of ground effects(weight)
