Dash Swap from 97 Trans Am into 96 Camaro
I want to swap the entire interior, including the dash, from a 97 Trans Am into my 96 Camaro Z28. What all needs to be done to make that happen? Will I need the gauge cluster from a 97 LT1 and do I need to change any of the wiring/connectors to do this swap? Does it matter if the gauge cluster is from a Firebird or Camaro? Camaro I know would have to be 97 if that fits in the TA dash.. not sure which year Trans Am interiors were the same?
Re: Dash Swap from 97 Trans Am into 96 Camaro
will need to splice some wires for the new 97+ gauge cluster...although i think you could use a 93-96 trans am gauge cluster and it should plug right in???.do a search for a dash swap and you should be able to find the diagram.....
other than that, pretty straight forward....just lots of 7mm screws ehhe.
Jul 4, 2005 05:00 PM
