Dash Pad Item #?
Old May 14, 2004 | 04:47 PM
jare23's Avatar
Dash Pad Item #?
my uppder dash is cracked and needed the item # from GM if someone happen to know it. anyone think they can help with this one? thanks.
Old May 21, 2004 | 03:37 PM
ElevensOrBust's Avatar
I actually have a used one from a '94 Formula in perfect condition I could sell you. Otherwise, if you need the actual GM part #, let me know. I have a CD with all the part numbers for all '93+ Pontiac F-body's
Old May 21, 2004 | 05:24 PM
jare23's Avatar
are u sure the firbird and camaro dash pads are the same? i thought they were different from the way the guage cluster is set up. mine is almost at the same level going across the pad. i beleive the firebirds had an up hill slant when it came to the cluster. i may be wrong but this is the way i thought they were. if not. how much you asking for and where u located at?
Old May 21, 2004 | 05:43 PM
AW/whiteZ-28's Avatar
93-96 camaro or 97-02 camaro dash pad?
They are different.
Old May 21, 2004 | 06:24 PM
n2ceptor's Avatar
93-96 part# 10267171
97-99 part# 10422746
00-02 part# 10410583
Old May 22, 2004 | 04:22 PM
magicvega's Avatar
what about a part number for the radio bezel for a 94 ?
Old May 22, 2004 | 04:25 PM
jare23's Avatar
n2ceptor: I appreciate the help with the item numbers but it turns out i wont need them. getting a trans in a week. thanks again though
Camarokid95
Jun 12, 2015 11:25 PM
May 1, 2015 01:14 PM
Blood type Z28
Apr 2, 2015 05:14 PM
nikko
Dec 2, 2014 03:43 PM
