custom grill
Old Dec 12, 2002 | 04:24 PM
2k2fbody's Avatar
custom grill
Does anyone here know of someone with a stock camaro grill with the camaro lettering cut out? I'm trying to put a red neon/ strobe light combination behind the grill to illuminate the camaro lettering. I tried using a sharp scalpal but the corners are just too hard to get to. Any information would be helpful, thank you.
Old Dec 12, 2002 | 04:37 PM
Teek's Avatar
Maybe trying a dremmel with a small sanding bit would work to get in the corners.
Old Dec 12, 2002 | 04:38 PM
nothingeined's Avatar
for the corners you can use a drill in each corner then a small low speed sawzall to cut out the letterings or a small reular saw blade. i was going to do that cutting out today but i only got through C cause it started to pour oustide. do you have any ideas on how to hook up the neon?? i would be interested in that cause i wanted to do the same.
Old Dec 12, 2002 | 04:44 PM
2k2fbody's Avatar
My neighbor works with neon and he is the one who is going to do all the electrical work. The only problem I had when cutting was making all of the edges uniform. That is why I am wondering if there is an easier way to do this. Either way I have to order a new grill because of all the little cuts I made on the first, they look horrible up close.
95chwagon
Oct 16, 2015 12:24 PM
kandied91z
Sep 30, 2015 11:43 PM
CARiD
Sep 30, 2015 05:44 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
