Crusty 4th gen headlights (pics)
Supposedly there is a moisture drain duct on the back of the 98+ headlamps. If there is moisture in there that won't go away, it'd be good to check and see that the drain duct on the back isn't clogged or something before drilling a hole.
i just read this. you just wetsanded them and they still look back? are you sure its not on the inside? after you take of the top layer of plastic and buff it it should be as good as new?
if there is moisture on the inside of the lense you can drill a SMALL hole on the bottom of the lense and it will get rid of it once you run the lights for a while.
the older ones got ****ed up and were foggy as ****, and still stained yellow, they werent crusty, but they werent clear at all.
all of the stuff on my lights is on the outside, and everything I seem to use on them doesnt last.
I can wetsand them, polish them and then theyll just have a foggy sanded look.
my current lights haven't been touched by sandpaper
Well .. like I said, those are BEFORE polishing. The sanding cuts the crusty
plastic off, but it will leave the plastic white and not too transparent. Polish
will clean the fine scratches off that create the whiteish hue. The pictures
dont show the whole story, they make the before pictures look better. The
yellow was gone, that alone made them look better, but polishing is REQUIRED.
Tom
Tom
I used Meguiar's Plast-X this weekend & it worked great w/o a lot of effort. I did it buy hand, no electric buffing. No more yellow. Sorry, I didn't take any pics, but that stuff works great. $5 @ AZ.
I bought the Meguiar's Plast-X, and resanded with 1000 and then followed
with 2000 wet sanding paper. The lens becomes almost white and barely is
see thru. I waited for it to dry, and rubbed it out by hand with the Meguiars.
What a difference. I have yet to be disappointed with a Meguiars product!
Tom
Tom
ChrisFrez
Feb 22, 2015 08:47 AM
ChrisFrez
Feb 15, 2015 08:12 AM
