couple more carbon fiber pieces
Well, I'm practicing big time to get ready for my "big project" but I have to get it to be "perfect" for that one. This second project of mine seemed to go a LOT smoother, and I'm finally getting the hang of it. Anyway, check it out:
http://meissenation.com/modules.php?...howgall&gid=98
Re: couple more carbon fiber pieces
Originally Posted by Brent94Z
How much are you going to end up doing? When done right the stuff can look pretty good IMO
looking good- getting the resin smooth is the hardest part of it- i made a carbon fiber stealth sub box this summer and it took almost 3 weeks to get it right.
even then theres a few small spots where i sanded through the resin and hit carbon before i re-applyed resin. im impressed
A little more fiber for the car's dietary needs.
http://meissenation.com/modules.php?...howgall&gid=99
I just finished applying the third layer of resin earlier today, so hopefully the part will be installed again and lookin' good for the UofM car show in Ann Arbor this Saturday.
I'm not a big fan of carbon fiber stuff, but i would be interested in knowing how its done. I thought you were putting some decals on at first until i saw the talk of resin and sanding. Anyone have some good info on it.
I don't want to speak for others, but this is how I've done my pieces... I'm still learning and such each time..
1. First, I scuff up the piece that I want covered with some rough sand paper. You really want to scratch the crap out of it, because it'll give more rough spots for the fiber to "stick" to and for the resin to soak in. After sanding it, I wipe it down with water or rubbing alcohol, anything to clean it up real nice to get the dirt off
2. I take the piece that I want to cover and lay it atop the carbon fiber. Once I've figured out the size I want, I take strong adhesive tape and tape off the line I want to cut. Using the tape helps hold the edges together after it's been cut, so the weave doesn't start coming undone.
3. Once sanded and cleaned, I use 3m Spray Adhesive and generously spray it all over the piece, usually it takes two layers before it gets REALLY tacky for me, I usually just keep spraying it on until my finger sticks to it real good. Once it's that tacky, I lay the carbon fiber that I've already cut on top of the piece. I "pat" the fiber onto the piece, because if you rub you could screw the weave up, and then you have to use a toothpick to straighten the weave out again. Once I have it all "patted" onto the piece, it's time for resin.
4. Resin is the second hardest part, IMO, because if you mix too fast, you'll get tiny little airbubbles in the resin and that's just a PITA when you are using resin that dries clear. Anyway, mix the ratio accordingly, and then I use sponge paint "brushes" because they're cheap. I let the resin soak into the sponge, and then again pat the resin into the piece, don't want to disturb the weave. The first layer is just to get it to stick to the piece.
5. Using a VERY sharp exacto knife, trim the unwanted carbon fiber off. Mix and apply second layer of resin, apply generously because now you want to start getting it to be smooth by the 3rd layer.
6. Third layer, apply heavy. Mix in surfacing wax, this makes the resin a little softer when it's dry so you can sand better.
7. Wetsand as much as possible to get it as smooth as possible. Use really fine sandpaper, you don't want to cause scratches.
8. Once it's all smooth, clearcoat.
Sorry the steps got less descriptive by the end, I'm running late for class lol thought I could type this out quicker than I did. After class tonight, I'll edit my post and make it more descriptive.
Thanks, much appreciated.
I can't really explain what it is about carbon fiber that I love so much, appearance wise. I think just the fact that it creates almost a 3d holographic effect with light is what really makes me like it. Not only that, but I have a very custom LED ambient lighting system (5 LEDs recessed down the center of my headliner, two in the dome light, one in each map light, and one over each power window/lock control piece) and the LEDs shining onto the carbon fiber at night just looks even better. All a matter of opinion though.
PS - Although I said I was going to update my steps after class, I reread it and I think the last steps are kinda self explainatory. If you need any more info tho, just let me know and I can answer to the best of my knowledge on the subject lol
Haha yeah, I did know about it, and truthfully now that I think about it, I don't know why I didn't use the red and black CF... especially considering the center console pieces WERE red before I covered them in fiber! Ah well, maybe the 2nd phase will be the red and black.
