clear corners
Old Nov 23, 2003 | 10:51 PM
HtownZ's Avatar
clear corners
i got clear corner lenses and i have a problem constantly with water getting in them. does anybody know what i can do to seal them, or maybe i should go with the APC or the Rksport eventhough they are $60?????
Old Nov 24, 2003 | 12:24 AM
SpecForceZ28's Avatar
my passenger side clear corner does this also
Has a light burned out since you got your clear corners? Mine did, and caused a crack in the area where you put your bulb, which explains why you are getting water in there.
Try and use some rubber sealant, or i'm sure someone will chime in and say, but it is fixable, no need to buy new ones.
Old Nov 24, 2003 | 07:36 AM
My84Z's Avatar
only thing you can do is take them out warm them up in an oven seperate them and reglue them or just live with it.
Old Nov 24, 2003 | 08:19 AM
DARK AGE 53's Avatar
This seems to be a common problem know matter what brand you're using, BTW what brand are yours?
Al
Old Nov 24, 2003 | 10:50 PM
HtownZ's Avatar
i dont know what brand they are, i got them from ebay, i thought it wasnt gonna matter but i guess it does. anyway, im still gonna trash them and get me the apc or rksport and this time i will seal them before i put them on!!!!!!!
Old Nov 25, 2003 | 07:23 AM
My84Z's Avatar
save your money and just reseal them yourself bake them in the oven and seperate them with a butterknife and just silicone them shut.
Old Nov 25, 2003 | 10:25 PM
gamer885's Avatar
Are the clear corners at procarparts.com any good?
Old Nov 25, 2003 | 10:49 PM
AW/whiteZ-28's Avatar
Yea they are good just FYI though just about all diamond clear corners leak but I have yet to see someone with regular clears that have a leak
Old Nov 26, 2003 | 10:46 PM
NeXplicit15's Avatar
I bought clear corners from Ebay about a year ago and i have not had any problems about water getting in them, although i do have problems with water getting in my aftermarket tail lights. My clear corners were on Ebay for only about $30 and they work fine. You could try maybe finding the leak and then using a hot glue gun to seal them, i tried that with my tail lights and it kinda worked. I am sure silicone would work better though.
Old Nov 27, 2003 | 12:30 AM
JSK333's Avatar
I've had APC clears for over a year, and still haven't had the Eurolite Xenon bulbs go out. They seal great. I think they were around $35-40 from www.carparts.com.
Old Nov 27, 2003 | 01:44 AM
gamer885's Avatar
Well is there any way to seal them up?
Old Nov 27, 2003 | 01:56 AM
Camaro_Guru16NY's Avatar
Take them out and let them dry then run a bead of silicone around the outside to seal them.
Good Luck,
-JOhn
Old Nov 27, 2003 | 02:24 AM
gamer885's Avatar
I could just seal them before i put them on as well? wouldnt be so much of a hassle taking them on and off to seal them.
Novo
Jun 14, 2016 02:58 AM
PopoFormula
Oct 12, 2015 04:19 PM
HAWG
Sep 25, 2015 11:41 AM
tommalcolm
Sep 11, 2015 03:39 PM
