cleaning exhaust pipes on car (used borla)
I got a used borla catback a month ago and wanted to know what do you guys use to clean your exhaust pipes and tips? Right now my catback system looks pretty dirty i wanted to hook it up.
thank you
kyze soze
thank you
kyze soze
Well i live in North Dakota and there is alot of Road SH*T here and you get all that hard stuck on stuff on your tips,... seriously try cleaning them with Lava Soap.... cleans them up grime and all.... then shine with whatever i use glass cleaner..
Foshizl, yu should keep your sig to five lines. Not to be testy or nothing but a moderator will soon tell you the same.
If I were you I would go ahead and coat them while they are off after you clean them too.
Re: never dull
Originally posted by dunkchamp55
i think its made by meguires, never dull, in a silver containter, i just found out this weekend that rim cleaner the spray on stuff works quite well, give that a try
heres a shiney borla
http://groups.msn.com/Camaro2001SS/borlapolished.msnw
check out this guys site ... he has hte most amazing camaro i've seen in my life .. cleanest shinest machine u could imagine
I always use simple Green to clean my exahust/engine and all that metal stuff. Does a pretty good job of it too. As for the rust, I guess you could sand it off, but it'll just come back worse. As long as it is just light rust, I wouldn't worry about it, keep it from spreading.
I seem to be the odd man out but I HATE never dull(sp). I bought it and used it on the polished Vortech elbow and it SCRATCHED THE H3LL OUT OF IT.
It has tiny pieces of something that put dozens of fines scratches in the elbow with only a few rubs. I switched to Wenol and personally I don't think that they even compare.
Anyone else have similar problems w/ it?
If someone wants the almost new container of Never dull that I have you're MORE than welcome to pick it up if you are near Rading, PA. I am too cheap to throw it away even after what it did to the elbow.
I was just reading this post and want to thank you for the compliment, it means alot.
Todd
