Chrome Valve Covers
Old Sep 22, 2003 | 07:12 PM
BlakeW5's Avatar
Chrome Valve Covers
Anyone have pics of these on their car. I found a pair made by spectre at autozone. Anyone know about Spectre's quality? Also, it said it fits '87 and up small blocks, so I assume it would fit our cars (just want to make sure).
Old Sep 22, 2003 | 07:18 PM
BlakeW5's Avatar
It's centerbolt, I was just wondering if our cars have anything else special about their valve covers (oil baffles, etc.).
Old Sep 22, 2003 | 09:25 PM
leadfoot94's Avatar
The passenger side cover has a "notch" taken out of it in order to clear the alternator. Unfortunetly this narrows down our options.
Old Sep 22, 2003 | 11:49 PM
krazzycowgirl's Avatar
There is an Adapter that you can get that converts your car from center bolt to outer bolt Valve covers.
but here is a set of OUter bolts on a Center bolt car.
http://www.angelfire.com/wa3/ivhorsepower/95.html
I found the Adapter Heres what it says.
Trick Flow Valve Cover Adapters for Small Block Chevy
Our valve cover adapters allow you to run early-style valve covers with your late model Chevy’s centerbolt heads. Plus, the adapter gives you the option of running a stud girdle to increase valvetrain stability and improve overall performance. The adapters come with all necessary hardware and gaskets.
Note: Requires narrow-body rocker arms.
Summit racing carries them for $99.95
Old Sep 22, 2003 | 11:52 PM
not if you are willing to raise the Alternator (if you have clearance under the hood) & have someone fab a bracket. Along with this you have to get a smaller fan for the Alternator & rotate it so it will not scrap up your hood.
HectorM52
Jul 30, 2017 11:46 AM
nikolt1
Feb 27, 2015 09:10 PM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
