Center console removal??
Old Jul 21, 2004 | 03:45 PM
bellcamaro's Avatar
Did a search and nothing really came up.. also didn't feel like checking all 50 pages of results.. haha
ANYWHO>> i have a 95 camaro. i took all the bolts off holding the thing in place.. it's completely loose, but i can't pry the damn thing out of there. The tape holder/cigarette lighter area keeps smacking into the radio area above it when i try to pull up and the ebrake keeps smacking into it when i try to pull out. DO i have to take the ebrake off? Take the radio area off? OR it seems like the entire back area of the tape holder area can be separated from it.. THere's some weird rubbery grommet or something with a hole in the center holding them together.. but i can't figure out how to pry the bitch off of there. PLEASE HELP.. my car is sitting outside with the center console on the ground as we speak. haha
Old Jul 21, 2004 | 05:01 PM
AW/whiteZ-28's Avatar
Re: Center console removal??
1 bolt in the tape holder
2 bolts in the center console door
1 bolt under the shift plate
take the shift **** off
take the shifter plate off
pull the e-brake so it's straight up
lift the back of the console and after it clears the ebrake pull back and take it all the way out.
Old Jul 21, 2004 | 05:31 PM
StreamlineZ28's Avatar
you can unhook the ebrake cable from the handle and then you can pull it straight up and down. then put the shifter in 2nd and pull back then up should come ut pretty easy. i also found it easier with my seats leaned back to give more room side to side.
Old Jul 21, 2004 | 07:55 PM
bellcamaro's Avatar
thnx guys
Old Jul 22, 2004 | 12:08 PM
coogsLS1's Avatar
whatever you do, dont just pull the ebrake straight up. check www.installuniversity.com and read the shifter install, it will tell you (with pictures) the best way to move the ebrake straight up.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
F'n1996Z28SS
Aug 23, 2023 11:19 PM
F'n1996Z28SS
Jun 3, 2015 09:39 AM
mattstrike
Mar 11, 2015 07:33 PM
CaRParts102
Dec 6, 2014 08:45 AM
