Calipur Paint
Old Jan 30, 2003 | 02:21 PM
KevinAce's Avatar
Caliper Paint
Hey,
What's the coldest you should attempt to paint calipers in? It's not a matter of comfortability, but a matter of the paint sticking. It's about 30 degrees right now (warmest it's been in a while) and I'm wanting to get this done.
Also, I plan on doing two coats of paint, then a layer of 'engine enamel clear coat' (haven't bought it yet, I believe that's what it's called). Is this the standard procedure, or are other things involved?
Let Me Know,
Thanks,
Kevin
Old Jan 30, 2003 | 03:03 PM
onoiocoko's Avatar
i think most people use primer first. and they use 2-3 coats not 1-2. are u sanding first or using brake cleaner also? good luck.
Old Jan 30, 2003 | 04:26 PM
KevinAce's Avatar
I was planning on just washing it off with soap and water and going with 2 layers of paint, one of clear coat. I haven't looked into this at all, so I don't know the standard procedure. What kinda primer (as in, when I go to AutoZone or whatever, what name brand / exact name should I get)? I'll probably end up doing 2-3 coats of regular paint. As far as sanding and brake cleaner goes, I wasn't planning on doing either of those. I was planning on keeping the brakes on the car, and just masking off the stuff I didn't want to paint. I'd imagine it'd be a bit hard to sand with it still on the car? Also, what kind of sanding are you talking? Sand blasting? And lastly, what clear coat name / company / brand should I use?
Old Jan 30, 2003 | 04:37 PM
naztyz28's Avatar
you need more then soap and water to clean those use brake cleaner its the easyest way to clean them .
Old Jan 30, 2003 | 04:40 PM
camaros_4_lfe's Avatar
use brake cleaner first.
then wire brush them alittle
then prime 2-3 coats
then paint 2-3 coats atleast!!!
then clear is optional wont do much since theres no light down there ne way
good luck
Old Jan 30, 2003 | 05:44 PM
MrCoffee's Avatar
I dont know what color you're planning on doing, but here's what I plan on doing. Should last longer than paint...
http://www.bambeezer.com/formula/calipers.htm
Old Jan 31, 2003 | 02:00 PM
96z's Avatar
96z
Just use something as simple as rustoleum. I did and mine have been fine for over 2 years.
Old Feb 2, 2003 | 02:15 AM
joed4640's Avatar
i did mine last spring, i bought high temp "caliper/engine enamel" just to be safe. make sure you clean them good or the paint will flake of
i didnt use any primer but used about 5 coats of paint, its not bad because you do the other calipers while you waiting for it to dry
mask everything, but dont freak if you get some on the rotor, one hard brake and it will disapear
and if its a little sloppy or runny no one will be able to tell, expecially if you have the stock rims w/ the wide spokes
its a great first paint job. mine still look bright red, i quickly clean them whenever i wash the car
-good luck
ps: MAKE SURE you pick up some caliper decals from afterthoughtsauto.com if you want to see some pics e-mail me ill send them over they look awsome
-joe
GREEN3112
Feb 10, 2019 09:19 PM
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
CARiD
Sep 30, 2015 05:44 AM
92_RS_305
Sep 8, 2015 07:47 PM
