Blasted Turn Signals keep blowing out every rain!
Old 06-21-2005, 03:27 PM
Need4Camaro's Avatar
97 Chevy Camaro with clear corners. Everytime it rains, my clearcorners keep blowing out. I make sure the bulbs are tight and secure, THEY ARE! I took the tape off of the condensation hole and that helped alittle...but every rain I'm always buying a new set of bulbs!
Whats up with this?!?!
Need4Camaro is offline
Old 06-21-2005, 03:28 PM
km9v's Avatar
Re: Blasted Turn Signals keep blowing out every rain!
You need to replace your blinker fluid.
km9v is offline
Old 06-21-2005, 04:03 PM
Please I've been victem of enough jokes for one day...
Old 06-21-2005, 06:16 PM
Wraith's Avatar
I read similar posts back when I first decided to get mine. From that I decided to take some silicon caulking and line a bead around all the seams prior to install. I have been fortunate not to have ever encounter any problems , even in some very heavy rains over the past 5 years.
Wraith is offline
Old 06-21-2005, 08:33 PM
I have Silicon glue is that helps... So just glue around all the seams and what about the hole where the bulb goes in?
Old 06-21-2005, 09:15 PM
RENE95Z's Avatar
I wouldn't silicone around the hole where the bulb goes in. That would make things alot more difficult to change the bulbs in the future having to break that loose. I think around the seams should be sufficient.
RENE95Z is offline
Old 06-21-2005, 11:43 PM
Wraith's Avatar
Right, I just did the seams of the lens, not anywhere around the bulb in anyway.
Wraith is offline
Old 06-22-2005, 10:57 AM
Z28SORR's Avatar
You can use dialectic or silicone based grease around the socket wires and socket gasket to help seal this area. This grease will not harm the plastic.
Z28SORR is offline
stangspank
11-13-2015 01:02 PM
vinnyxgunz
08-28-2002 09:41 PM
Darth Xed
13
07-22-2002 12:45 PM
CMJ917-95CMO
06-19-2002 09:10 PM
Quick Reply: Blasted Turn Signals keep blowing out every rain!
