Billet Aluminum Dash Bezel
Got the gauges picked out I think for the dash project. . I downloaded the ones I want off the net, sized em' to the specs on the site & printed the faces out on the printer. Then I cut some PVC gauge housings on the CNC. They are a little deeper than the actual gauges but that'll insure I have ample room for the real deals down the road. Now I can make a bezel. That outta' keep me busy for awhile.
Cut the bezel out on the CNC. There's a bunch of steps to get this thing cut. I keep thinkin' one BooBoo & it's scrap.
Got the bezel off the table. Now comes the task of bending it in the right places & at the correct angles to fit the dash.
Got it roughed into the dash cover. Still rough but close enough that I know it will fit. The right wing is 1/2" longer than the left wing, so angles are different. I think I got it purdy' close though. Next is to cut the contour in the fiberglass for the oversized tach & speedo.
{that's a relief}
{that's a relief}
Got a little further on the dash yesterday. I made plugs out of PVC to form the gauge wells, since these gauges are too big for the original bezel opening.
I did the kitty hair "form the bezel to the dash deal" again. Used vinyl & spray Pam as a release agent.
I welded some strap aluminum to the top & bottom to stiffen up the bezel & to provide a place for rubber mounting grommets.
Got the bezel just setting in place. It's being held in by the dash bar. Close enough to see what it'll look like.
I got a chance to work on the "Z" for awhile today.
Got the dash bezel mounted. It was a pain since I had to tack weld the mounts in with the dash cover in place to keep the bezel in the right location. But, I got-r-done. Might work on the steering column next.
