Bad A$$ Custom tweeter install !! Check it out!
Old Jul 29, 2004 | 09:25 PM
ponykiller z28's Avatar
http://memimage.cardomain.com/member...59_52_full.jpg
scroll down later in this post for pics of the driver's side....
i've never seen this install before.... maybe its a first?
tell me what you guys think. it was actually really easy to do
Old Jul 29, 2004 | 09:29 PM
Wraith's Avatar
Re: Bad A$$ Custom tweeter install !! Check it out!
i have seen similar, as well as at the base of the a-pillar, and thqt cap that goes on the side view mirrors. To far from the midrange for my tastes, but if tuned right, why not. The only other downside would be they are baking in the sun.
Old Jul 29, 2004 | 09:47 PM
yeah, i used to have them in the vents in the a pillar but they just didn't fit right so i bought new a pillars and put them where they are now... i was hesitant to drill such a big hole in the dash but luckily it came out to be a flush perfect fit.
Gord's Avatar
how did you do that? I love it
Old Jul 29, 2004 | 10:17 PM
Use about a 1.5" (or however big the base of your tweeter is) circle doorknob drill bit and cut the circle above the air vent as pictured. Pull your air vent out to make sure you don't go too far over (there is only one spot that is hollow enough to drill through) If your hole is the right size then the tweeter mount should slide right in and the rim of the tweeter should fit flush to the dash. I ran my wires through the hollow compartment between the glove box and airbag.
Old Jul 30, 2004 | 03:22 PM
Here are some pics of the driver's side install:
http://memimage.cardomain.com/member...59_55_full.jpg
http://memimage.cardomain.com/member...59_54_full.jpg
Old Jul 30, 2004 | 04:50 PM
BradleyPeart's Avatar
Looks great! Very sharp.
I'd be scared to cut into the dash. I've got the mounts on the side view mirror cap.
Old Jul 30, 2004 | 05:08 PM
o believe me, i was. When styrofoam (spelling??) started flying everywhere i thought to myself.."what the hell am i doing!" .... but luckily it turned out perfect
Old Jul 30, 2004 | 05:31 PM
F1GT's Avatar
I wouldn't exactly call that flush, its popping outta the dash. The best place for concealment would be the shark fin where the mirror is.
Old Jul 30, 2004 | 06:48 PM
the rim of the tweeter is sitting flat against the dash. The round, bottom part of the tweeter goes down in the dash about an inch and the rim stops it from pushing on through. Thats as flush as it gets. I never said it was concealed.
Old Jul 31, 2004 | 10:52 PM
DontMixWithRice's Avatar
ponykiller hook it up with a list of what needed to be change for the swap. i need a list from someone that has done it...along with there experience to see what i could avoid! thanks dude. i am aware of teh tacreations' swap list, but i rather have one from you.
Old Aug 1, 2004 | 07:47 PM
i sent you a pm
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CARiD
Jan 14, 2015 04:00 AM
Collector Car
Jan 5, 2015 10:58 AM
Wilson
Jul 21, 2002 05:08 PM
