amp painting
Old Jan 31, 2007 | 03:44 PM
blackz151's Avatar
amp painting
iam getttin ready to paint my jl amps. I just wanted to know what prep work i should do to the amp covers b4 i spray them
Old Jan 31, 2007 | 08:53 PM
shock6906's Avatar
The normal stuff that you would do to anything that you're about to paint. Scuff it with some light grit sandpaper and then hit it up with some alcohol or something of that nature to get all the grease off of it.
Old Jan 31, 2007 | 10:09 PM
oneslowz28's Avatar
Heres my fool proof 8 step system.
1.Scuff them up with 400 gritt, Make sure to get all the little nook and crannies in the process
2.Wipe with wax and grease remover then tack cloth.
3.Prime with epoxy primer ********
4.Scuff with grey scotch brite pad
5.wipe with wax and grease remover and tack cloth
6.spray base let flash
7.spray with clear.
8.Let them cure for 24 hours before reinstalling.
********If your just using a rattle can or single stage paint prime with rustolium bare metal primer. Then follow steps 4,5,8
GREEN3112
Feb 10, 2019 09:19 PM
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
CARiD
Sep 30, 2015 05:44 AM
92_RS_305
Sep 8, 2015 07:47 PM
