Air Ride
Old Jul 30, 2004 | 01:43 AM
  #31
kandied91z's Avatar
Re: Air Ride
more then enough....you can set it how you like but when it's fully up i can crawl under the car without a jack and when it's low it sets the gfx on the ground. i'm sure you could go higher if needed by i wouldn't see the need.
rise time or quick valves as you refer to often times are controlled by the size of the valve, line and how much air you can push so upgrading to 1/2" valves or even larger with a big tank will do the trick. you could even mount the valves real close to the bags to make them that much quicker. plenty of tricks but to be honest it isn't necessary on our cars and just an added expense. the ride pro or 1/4 definately aren't considered fast but they would be fine for a sports car. the 3/8 big red like i have work great but it's definately faster making target pressure hard to get to.
Old Jul 30, 2004 | 07:38 AM
  #32
blackz151's Avatar
Re: Air Ride
that cool i was just worried that it didnt move that mutch. Thankx for all the info it helped alot and i will be callin air ride in the next few weeks to place a order
Old Jul 30, 2004 | 01:40 PM
  #33
kandied91z's Avatar
Re: Air Ride
if you do go through with it ask for darren.....
Old Jul 30, 2004 | 06:17 PM
  #34
blackz151's Avatar
Re: Air Ride
will do
NewsBot
Apr 22, 2015 09:50 PM
squarehead
Jan 15, 2015 07:02 PM
95chwagon
Jan 13, 2015 09:19 PM
Collector Car
Jan 5, 2015 10:58 AM
