aftermarket ss hood =(
Old Oct 1, 2003 | 08:38 PM
Terran2k's Avatar
I have an American sport car design ss hood, got it used to put on my Z. but there seems to be a problem with the front, doesnt follow the curve of the front fenders at the front, the edges stick up about 1/2 cm higher over the fender right where the hood ends. and the right side doesnt have a nice space between the hood and the fender, it gets a bit wider right at the end over the headlight. what you all think? maybe I need to fiddle with it more to get it right? dunno how much more I can fiddle since its not much to adjust. can a body shop fix it? thanks
Old Oct 1, 2003 | 08:50 PM
Brent94Z's Avatar
Super Moderator
There is actually a lot more adjustment than one would think. A good body shop guy (with some experience at doing this) can usually get hoods to look pretty good by adjusting the hood and fenders. I would think you'd be able to adjust out 1/2 cm difference so there is hope!
Old Oct 1, 2003 | 09:28 PM
bigdreamZ's Avatar
1/2 a cm are you kidding? thats nothing! Like Brent said you could easily get that to line up. My hood was off like an inch
Old Oct 1, 2003 | 10:50 PM
LimitedEd1LE's Avatar
If the hood fits like **** then I would take it to a good body guy and have him fit it on your car. I have that same hood and it fit perfectly on my car. The only thing I had to do was to lower the hood hinges down a little cause the hood was a little high by the window.
HibachiZ28
Nov 6, 2015 12:53 AM
Henson071
Sep 18, 2015 04:01 PM
95mysticta
Aug 20, 2015 07:43 PM
TGGodfrey
Aug 17, 2015 08:43 PM
4586
Aug 13, 2015 10:11 PM
