? about lowering
Old Mar 2, 2004 | 11:50 AM
30thANNIVZ-28's Avatar
Question ? about lowering
I want to lower my car and I've heard you need the lower control arm relocation brackets. My question is instead of adding the brackets could I just install adjustable lower control arms? Or do they do hand in hand?
Old Mar 2, 2004 | 01:17 PM
94BlackBowtie's Avatar
It all depends on how much you are going to lower it that decides what all you MUST do. What lowering kit are you looking to get?
Old Mar 2, 2004 | 02:20 PM
speedracer93z28's Avatar
the adjustable lca's will just move your rear end back or forward depending on how you adjust them. the lca relocation brackets will return your lca's to the correct angle, in other words you dont really need the adjustable lca's. if you go really low you might want to look into a panhard rod to center the rear end. i have sportlines with stock panhard rod and lca's.
Old Mar 2, 2004 | 03:44 PM
ive got the adj PHR. I was either just going to get the BMR springs or teh prokit nothing major. Just wanted the car to sit a little lower.
n2oblkz
Oct 22, 2015 02:31 PM
n2oblkz
Oct 12, 2015 01:53 AM
Hal Fisher
Sep 30, 2015 09:03 PM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
alliance12364
Sep 23, 2015 12:40 PM
