98-02 Camaro headlight replacement
Old Dec 30, 2003 | 12:19 PM
jaburkholder's Avatar
Angry 98-02 Camaro headlight replacement
Looking for some help on "How To" remove the factory headlights on a 98-02 stock Camaro. Having difficulty figuring out how to attempt the job. Want to install replacements (org equip badly sun burned). Any help greatly appreciated.
Jim Burkholder
Old Dec 31, 2003 | 09:01 AM
FLALS1's Avatar
1st you need to unbolt the bracket that goes from the frame to the light assembly. Its a piece that about 4inches long. Then unplug the lamps. Then you slide the assembly towards the center of the car. If you look down by the bottom of the light you can see the groves that it slides out of. Then you need to pull the outer corner out( the pointy end). Thats the pain in the a$$ part.
Then just manuver it out.
Old Dec 31, 2003 | 10:23 AM
AZWingNut's Avatar
It helps to pull the plastic fastners across the front of the nose and gently pull the facia out of the way.
ddr698
Jan 9, 2015 10:05 AM
Hurin
Dec 13, 2014 07:38 PM
CaRParts102
Dec 6, 2014 08:45 AM
Dec 4, 2014 11:56 AM
siguy
Nov 27, 2014 10:07 AM
