96 trans am parkinglight/headlight mod?
i am sure this is nothing new but i am having trouble finding the info i need.
my headlights go up when i put the parking lights on. i want to be able to turn on my parking light and fog lights without my headlights going up.
how is this done. a link or an full description will be fine.
I believe it's a sign of problems in your motor. My car does the same thing. I HATE it. This is what they've told me in the past.
Also, when my headlights go down you can hear the gear grinding.
These might help: http://www.bfranker.badz28.com/headl...x.htm#Ordering
my headlights work fine.
when i turn the parking lights/foglights only on i don't like the fact that my headlights flip up. they are not on but they still flip up. are you saying that is not suppose to happen? because i was under the impression all of the 93-97 firebirds did this.
yes i have a trans am. i move the **** to the first setting and the headlights flip up but not on. and my parking lights and my foglights (if they are on) turn on.
i only want the headlights to flip up on the second setting
So I checked the relays ( in the box under the hood) and put it back in and it works like you want it to.
My motor is also going bad and might be part of the prob aswell.
Try that and see if it works. Good luck
what would i be checking for? they go up and they go down.. other than that what am i checking for. they shouldn't be getting power off the first setting if that was not what it was designed to do.
