95Z front plate question
Old Dec 9, 2007 | 02:46 PM
mike445's Avatar
From: Wasaga Beach, ON (formerly Ft. Lauderdale,FL)
Question 95Z front plate question
I have a 95 Z28 and am going to be adding a billet grill. Here in Ontario we HAVE to have front plates or we get a $110 ticket. We can't even put the plate in the windshield. I was wondering what others have done (I saw the earlier license plate post..it was for a 98, not helpful). I was thinking of using the factory plate holder and somehow modifying it if its possible. I don't really want to modify the grill. Any suggestions? Thanks.
Mike
Old Dec 9, 2007 | 11:21 PM
FiefSS's Avatar
The SLP bracket for 98+ LS1 cars should work fine. I have it on my car thanks to a very unfriendly Illinois state trooper.. Otherwise there really is no solution for your car unless you modify the original bracket which will ruin the looks of the new grill.
Old Dec 9, 2007 | 11:32 PM
Kaj's Avatar
Kaj
You can roll (bend) the license plate to make a slight curve to fit flush with the grille, and zip tie it It looks good if you do it properly.
Old Dec 10, 2007 | 02:44 AM
CamaroRacing12's Avatar
air dam mod?
Old Dec 10, 2007 | 10:20 AM
RS96Silver's Avatar
does that actually pass with mountin it on the air dam?
Old Dec 10, 2007 | 12:12 PM
Z28SORR's Avatar
Or you could do this: http://www.youtube.com/watch?v=Y0TS3SInyoY#GU5U2spHI_4
Old Dec 10, 2007 | 02:57 PM
mike445's Avatar
Exclamation
We can't do the air dam thing up here. I love the plate flipper in the YouTube video!!!! I can't find it anywhere though. I may have to go with the SLP mount. I checked it out and it works on 93-02 Camaros so I think I'll order it. Anyone knows how and where it installs? I was trying to find instructions but had no luck. Anytime I leave Onterrible I'd like to remove the whole damn thing. Thanks!
Mike
Old Dec 10, 2007 | 09:33 PM
FiefSS's Avatar
You pretty much popup a few plastic retainers from the bottom of your front bumper. Drill 2 holes and bolt the front plate bracket on that way. Takes about 10mins, unless you try to do it with the car not jacked up. That was fun When I have a chance I am going to make it so mines easily removable.
Old Dec 10, 2007 | 09:56 PM
mike445's Avatar
Thanks!! Will it fit ok with ground effects? I have the RK Sport CA300 kit. It is pretty thin in the middle of the bumper though. Thanks!
Mike
Old Dec 10, 2007 | 10:22 PM
FiefSS's Avatar
With the ground effects I am not sure. But you can probably make it work, the bracket will bend if you need it to. I'm sure you can come up with something.
I ordered mine here
http://www.afterthoughtsauto.com/camfronlicpl.html
Shows a picture of the actual bracket. It does dip so it might clear the ground effects without any modifications.
I don't have many pictures with the bracket on but heres one example.
Old Dec 11, 2007 | 10:20 AM
Z28SORR's Avatar
After Thoughts Auto
These are great folks, by the way!
oldschool
Feb 9, 2016 09:21 PM
Brake_L8
Jan 20, 2015 09:44 AM
Queens94z28
Dec 20, 2014 09:11 PM
Hurin
Dec 13, 2014 07:38 PM
heavenly_six
Dec 10, 2014 12:23 AM
