93-97 headlight conversion on ebay
Old Feb 11, 2004 | 09:46 AM
Brundle's Avatar
came across this auction this morning:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33710
just curious if anyone else saw these b4 and knows if these r the same type that brent franker used?
or if brent sees this, if u you could chime in and give you .02 cents
and is it just me, or do those pics with the lights on look yellow like stock bulbs? i know it is a day time pic, but still.....
just curious, cause if these r decent kits, i might be interested in buying one. but not till i get some other opinions
Old Feb 11, 2004 | 10:19 AM
93Z286Speed's Avatar
Brent Used PIAA lights, i belive they were in upwards of 600$
dont think those are the same lights
Old Feb 11, 2004 | 10:28 AM
Brundle's Avatar
true....
i was just askin cause they didnt specify the brand and they looked similar to brent's when comparing the pics
but i guess that wouldnt justify the price difference....
Old Feb 11, 2004 | 10:30 AM
Brent94Z's Avatar
Super Moderator
I would email the guy and ask him the brand name and model number of the lights being used. If he is not willing to give you the actual brand and model then they probably aren't the best. If he gives you the brand and model then post that on here and the lighting experts will give you a thumbs up or down as to how well they will work as headlights
While my PIAA lights are real good and expensive lights, they still give out a fog light pattern which makes them not the "best" for use as headlights. They are acceptable and probably as good as the stockers for headlights but from what I've read, the Hella option over the PIAA is a much better option (and cheaper) when using these as headlights.
But, as for the auction, see if he'll tell you the name and model of the lights and that will allow you to do some research to see how good these will be for headlights.
Old Feb 11, 2004 | 03:00 PM
30thZ286speed's Avatar
Instead of getting foglights for replacements, what if you use driving lights. Would that be better than using fog lights since driving lights have a longer light beam?
Old Feb 12, 2004 | 08:56 AM
pu12en12g's Avatar
My opinion is avoid that auction at all costs. Using foglights as driving lights is not safe.
Your best bet is the Hella 90mm conversion. Do a search on "Hella 90mm"
Old Feb 12, 2004 | 10:34 AM
Brent94Z's Avatar
Super Moderator
I agree with ya about the Hella lights but I don't know if I'd go so far as to say "unsafe". At least not in the case of my PIAA lights. While they don't give off the superb light like the Hella conversion would, they light up the road as good as the stocker headlights
Old Feb 12, 2004 | 10:52 AM
Brundle's Avatar
thanks for the input everyone. i kinda figured it was something to stay away from n e ways.
seems like all conversions r a bit too expensive. at least the good ones that is. i may just go the cheap way and open up my sealed beams, put in some hyperwhite bulbs and call it a day.
Old Feb 12, 2004 | 10:55 AM
pu12en12g's Avatar
If the bulb is tinted at all, make sure the bulbs are 80w or higher. Also, for best results get a heavy duty headlight harness. This will give your bulbs more voltage (steady too).
Old Feb 12, 2004 | 11:30 AM
Brent94Z's Avatar
Super Moderator
pu12en12g, I suppose in all fairness, some consider the stocker lights to give off such crappy lighting as to make it unsafe (or unsafeR than it should be!) so in that case, you would be correct
Off subject, you were asking about entertainment centers a few months ago. I finally have pics of mine, you want me to shoot you an email of what I ended up doing?
colts0455
Oct 4, 2015 09:47 PM
Hal Fisher
Sep 30, 2015 09:03 PM
karpetcm
Sep 29, 2015 10:08 AM
Greg88
Sep 20, 2015 07:14 PM
jackpawt883
Sep 10, 2015 08:53 PM
