93-96 tailights on a 97+
http://www.thedarkangel.info/conversion.htm,
Yes, here is my writeup of converting the harness so they work the same too.
I did that conversion. looks 100% better in my opinion. I dont like tha amber and the lines on the lights work much beter with the lines of the car. Look closely you will see what i mean. As for converting the wiring I did not do that. The lights still work but only the lower part under the reverse light flashes. I would love to do the wire conversion but need advice on how to do it. I have a rear light harness from a 93 so i can use that if it is easier or i can use the stock 97 that is in the car now. Any help would be great.
Dark Angel, link isnt working.
Thanks guys!!
Ed
Thanks guys!!
Ed
Funny thing, I just converted my 96 Z to the newer taillights cause I like them a lot better. I had to run a single wire from the the front to the back since the older cars have 4 wires and the newer lights require 5. I am now selling both of my taillights, perfect condition with no scratches along with the stock wiring harness. The swap is easy for you since you won't need to run a wire. If your interested in the lights and wiring harness e-mail me at nealeugene@hotmail.com
thanks,
thanks,
GoldThorvy
Jul 27, 2002 07:18 PM
