90 mm Hella project mostly done, pix
Old May 30, 2005 | 10:01 PM
Bud M's Avatar
The project is not done because I still have to put in the upper supports for the brackets but thought you might like to see anyway. Pix at the link in my sig.
Old May 30, 2005 | 10:04 PM
meissen's Avatar
Re: 90 mm Hella project mostly done, pix
Looks good! The more I see of the Hella conversion, the closer I get to doing it myself... I think it'd go great with my DG Motorsports grill. Great job on the install, looks great on your car! Got any pics with the hood down?
Old May 31, 2005 | 11:21 AM
Daddyo's Avatar
looks good.
Old May 31, 2005 | 06:45 PM
ImportKILLER's Avatar
Hmmmm...I may have to take a 2 hour trip north sometime soon.
Old May 31, 2005 | 09:17 PM
Bud M's Avatar
Sure, I'd be happy to have a chance to show off
meissenation: Now there's a front pic with the hood closed.
Old May 31, 2005 | 10:08 PM
pu12en12g's Avatar
Are you using the mounting brackets or making your own custom ones ? ?
Any chance you could take some closeup pics of how the low beams are mounted ? I've been working on this install for weeks now.
Old May 31, 2005 | 10:09 PM
meissen's Avatar
Gorgeous!
Old Jun 1, 2005 | 12:03 AM
Bud M's Avatar
Well you can see I used Susquehana Motorsports flat brackets along with some mounts made from 1.5 x 1.5 x 1/8" angle aluminum from Home Depot and screwed them onto the plastic frame that holds the stock lights like this. I had to remove some plastic for the lights to clear, mostly on the low beams. I also had to cut a hole in the chassis crossmember behind the housings. I did that with a cutting wheel on a Dremel.You can see the hole behind the low beam in this pic.
Old Jun 1, 2005 | 09:40 PM
xstoyz's Avatar
Bud M,
You do some really nice work. That car shows it!!
Ed
Old Jun 2, 2005 | 03:06 AM
ZRAPTOR's Avatar
Nice work there man.That is the best install of those i've seen yet.Looks like the easiest one too.
Old Jun 2, 2005 | 07:45 AM
pu12en12g's Avatar
Originally Posted by Bud M
SWEET JESUS ! !
YOU just solved my entire install problem ! ! ! I can't believe I didn't think of that ! ! That's ****ing awesome man ! !
Old Jun 2, 2005 | 09:42 PM
Bud M's Avatar
Thanks for the nice comments, guys
Old Jun 2, 2005 | 09:45 PM
Bud M's Avatar
One final tip: Susquehana also sells 9005 and 9006 jacks with wires 6" or so attached. Put the H9 jacks that are supplied with the Hella lamps on the wires and it all plugs together real easily.
Old Jun 3, 2005 | 04:27 PM
speedracer69's Avatar
looks good!!! i like it alot!
Old Jul 20, 2005 | 08:12 AM
pu12en12g's Avatar
Hey Bud... do you know what the material is that the mounts are screwed into underneath ? Is it just hard plastic ?
