35/5w Nokya's too much for stock corners?
Old Apr 2, 2003 | 08:48 PM
94BlackBowtie's Avatar
35/5w Nokya's 2 much 4 stock corners? & other corner bulb ?'s - P.T. enter please.
What is that you have Paul? Aren't they 35/5 Nokya's in an aftermarket clear? What have people gotten away with in the stock corners, and what have people melted the stock corners with?
I can get some lower wattage, but I need as bright as I can get...you will see pics tomorrow as of why...
Also - Paul, what are you using in your 194's and do they match ok?
And also #2 - what is the highest wattage 194 you have seen and what is safe in the stock housing?
Old Apr 3, 2003 | 11:54 AM
Let's try this again today...
I am also about to order Raybrig 15w hyperwhite 194's, unless some one suggests otherwise.
Old Apr 4, 2003 | 07:52 AM
pu12en12g's Avatar
I actually don't run any 194's at all
...and my 3157's are only 27w/7w where did you find the 35w/5w ?
Old Apr 4, 2003 | 08:17 AM
I thank God for you P.T....
I actually found the 35/5w Nokya's from a link you supplied me with a long time ago...Supercarauto - here. I assume they are 35/5w because of the numbers that appear on the box. They may actually be lower wattage (the whole "out output ='s" thing), but I was under the impression that Nokya supplied actaul wattages.
So do you think that they would be too much for the stock corners?
Old Apr 4, 2003 | 01:36 PM
pu12en12g's Avatar
Oh cool.. so you are going to use 1157's instead of 3157's ?
I think the wattage should be fine.
Old Apr 4, 2003 | 01:38 PM
3157 = Square base...Mine have the round base.
Mine uses 2397's stock, and 1157 is a cross reference.
Old Apr 5, 2003 | 05:43 PM
pu12en12g's Avatar
Oh did this change from 94 to 95 ?
Old Apr 7, 2003 | 07:01 AM
Apparently so...
The Sylvania website lists 2397 for both years, but if yours is square base, then I suppose it had to change. They show it changing in '96.
Old Jul 11, 2003 | 02:25 AM
pu12en12g's Avatar
How are the 35/5's working ? Any problems so far ?
More importantly.. any PICS ? ?
Old Jul 11, 2003 | 04:13 AM
SilvercamZ28's Avatar
I also don't run the 194's.. I think it looks much better!
Old Jul 11, 2003 | 06:06 AM
Actually - I decided against them.
Reason's being - I picked up some 27/7w's at a local store for the convenience to see how they would do (also hyperwhite, aka: highly tinted glass) - and they would barely shine through my housings (I got them blacked out you know...)
So I figured even with more wattage on the high side, the others wouldn't be much better - especially if I didn't keep them in DRL mode.
I would like to find a higher wattage clear bulb, but don't know who would make them. I am just using the 2397's now, and have a feeling that the 1157 may be a little higher wattage - got to find out.
Sorry though man - I backed out on ya.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 25, 2015 12:01 PM
dale3in98
Feb 14, 2015 12:18 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
