2002 ws6 wheels on 1996.
Old Mar 13, 2003 | 11:59 PM
A&FLs1's Avatar
I have read posts about having to bore out the center hole on the wheels to make them fit. Will I have this problem or is it only for 95 and before.(since ws6 came back as a package in 96) Any help is appreciated. Thanks in advance.
A&FLS1
Old Mar 14, 2003 | 07:36 AM
caspergotaz28's Avatar
http://web.camaross.com/forums/showt...threadid=93298
When I put '98 Camaro 16" rims on my '94 V6 years ago, I had to grind.
Everybody seems to have a different experience. If you do have to grind, it will not be enough material where you can notice it with the eye. Were talking fractions of a millimeter.
The best way is to use a "Dremel" with a drum sanding kinda bit. If you don't have/want a "Dremel" you can use a drill with a drum sanding bit.
Make sure to do all four wheels at the same time so you can rotate later with out grinding again.
QuickSilver02
Apr 7, 2015 11:12 AM
TitoPR221
Jan 2, 2015 03:51 PM
formula79
23
Jun 20, 2002 01:42 PM
