2000 Trans Am Seats in 94 Z28
Old Jan 24, 2006 | 06:49 PM
94ZVert's Avatar
Well, I finally got my hands on a set of trans am seats (all power, lumber) to replace my worn out cloth ones. Now, I've done a search but couldn't find the answer to this one.... Do they bolt directly in to the 93-97 camaros? I was pretty sure that I read somewhere that they were directly plug and play but now I can't find where I read that. Anyone care to chime in? Thanks....
Old Jan 24, 2006 | 06:54 PM
Z95m6's Avatar
Re: 2000 Trans Am Seats in 94 Z28
Yes they bolt right into place and the wiring will plug right in as long as you have the TA wiring harness that has the air line in it. If you don't have that you need to locate one, then it will be a simple plug and play deal.
Old Jan 24, 2006 | 07:03 PM
94ZVert's Avatar
Thanks for the info. Also, I was checking out your car, which is pretty nice by the way, and noticed that you also changed out your door panels to the T/A ones. Where did you drill the holes to mount them? I've seen a write up on it but it doesn't show where the holes should be drilled. Thanks again!
Old Jan 24, 2006 | 07:10 PM
Z95m6's Avatar
The easiest thing to do is just put the door panel on and drill the holes through the panel. The door panels have plastic clips that will hold them in place while you drill the holes. There are two little bumps that your old camaro door panel mounts to and you are suppose to cut those off. I don't know if its necessary but people say to do it so i did it.
Old Jan 24, 2006 | 07:34 PM
94ZVert's Avatar
Any particular screws that you used? Length, etc? Thanks
Old Jan 24, 2006 | 08:27 PM
Z95m6's Avatar
I just reused the ones from the camaro door panels.
Jan 5, 2015 07:14 PM
Joes96z
Dec 14, 2014 04:03 PM
siguy
Nov 27, 2014 10:07 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
25th T/A
Jul 28, 2002 06:46 PM
