2000 Camaro fog light replacement
Just wanted to know is the 98+ camaro fog ligts are a sealed system or can you change the bullb? If so does someone know the part number? Thanks.
Re: 2000 Camaro fog light replacement
It takes replacement bulb 894. The assembly it goes into is made of glass so the light that comes out is a little different than from the plastic headlights.
I've replaced mine with Plasma Glow bulbs. I'm sure you could use any brand you like though.
http://www.plasmaglow.com/index.asp?cat=146353
30thZ286speed
08-03-2002 04:54 AM
2000silverz28
07-20-2002 06:14 AM
