1969 Z/28 emblems?
Old Sep 22, 2003 | 06:01 PM
stang_killa94's Avatar
1969 Z/28 emblems?
I feel almost dumb asking this but i want to make sure before i spend 70 bucks..........I want to order the 1969 Z/28 style emblems for my fenders and the only place i have found them has been on ls1speed.com and in the describtion it says that they fit 98-02 but will it fit 93-97?? There should be no difference right?
Old Sep 22, 2003 | 06:11 PM
SloTexanTA's Avatar
As far as I know there is no difference. I don't think that part of the fender is any different between the years, so you should be good to go.
Tom
Old Sep 23, 2003 | 10:44 AM
z28marine's Avatar
i got some off ebay for like $30...try there before buying for $70
Old Sep 23, 2003 | 10:51 AM
SuperDave479's Avatar
I think the point here is they aren't made for anything but a '69 but like everything else, they can be made to work. Note that if you get one for the rear it won't fit under the taillight. I had a different approach for mine. Pics on my site in the sig.
Old Sep 23, 2003 | 03:17 PM
hmpm....i never though of putting it in the middle. I've been in contact with Brent about making somethign that will fit under the tail light.....still waiting to see what he says i know it wont be a 3d emblem but i think it'll be a nice thouch to have it there. What type of "modification" did you have to do to the emblems? What did you use to stick'em on there?
Old Sep 23, 2003 | 03:20 PM
I broke off the posts with vice grips, bent the emblems to fit the shape of the car with them as well (with a towel for a buffer) and used 3M Emblem tape to put them on. The tape is gray so I used a black Sharpie on the area around the emblem where the tape might be visible later. On the front one I used metal epoxy to attach it to the billet grille.
Old Sep 23, 2003 | 09:47 PM
JETMAN95Z28's Avatar
I went through the same thing my self. You have to buzz the posts off the OEM emblem and re-contour (flatten) them to fit the different lines, and use the 3M side molding taped mentioned earlier. I get MANY comments on mine, especially on a black car compared to the invisible stock emblems.. Take a look at the pics in my sig for what I did for my car. Sometimes I like it and others I don't. I've seen the 70's vintage "Z28" used under the tail light as it doesn't have the "/" between the Z and 28 to get in the way. I actually like the "/" and is why I put mine where I did without cutting up a $35 emblem.
It's the Bowtie I'm not sure about either..... in conjunction with the Z/28 badge back there. Should it stay or go?
what do you guys think??
Old Sep 24, 2003 | 01:28 PM
Ponykillr's Avatar
Check my sig for pics. I filled in the CAMARO leters and placed the rear emblem in the middle of the tail panel. I also put the 69 side emblems on the quarter panel with 3m after removing the posts. I attached another rear emblem to the front grill with 3m leaving the posts on. I can make you a flat black tail panel for $100 if you would like that will accept a rear 69 emblem and all letters filled in. I have an extra tail panel.
brothaslide
Jan 9, 2016 12:11 PM
mark0006
Aug 29, 2015 09:45 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
Jlo
Jul 29, 2015 03:52 PM
