18 inch rim fitment
Old Sep 17, 2002 | 01:28 AM
sorryofficer's Avatar
18 inch rim fitment
Gonna be buying rims in the spring when the car comes out of storage. I'm trying to decide on 17's or 18's. I am definitely leaning toward the 17's because of the way cheaper tires. I was also curious, what has to be done to fit 18*9-9.5 rims, what about 18*8-8.5? Do I just need a backspacer for 17*9, and what about 17*8.5?
I know I've got a bunch of questions in there, BTW, the rims I'm looking at are C5 chrome replica's.
Thanks for any help
Old Sep 17, 2002 | 01:40 AM
pu12en12g's Avatar
Definately go with the 18's I can hardly tell a difference between the 16's and 17's ... go with 18's and a 40 series tire, and you can get ride of the ugly wheel gap ! !
18x9.5 should fit just fine, there are several on here that run the C5 wheels with no problems.
C5's will look great ! But remember chrome=HEAVY
Old Sep 17, 2002 | 04:41 AM
whiteheartbeat's Avatar
Arrow
Go with 18's, Pu12en12g is right ,with 17's you wont be able to tell!! 9.5's fit fine with a seven inch backspacing!!! I have 18x8 in the front 255/35/18 ,18x9.5 285/35/18 rear
Old Sep 17, 2002 | 02:25 PM
blown383's Avatar
I plan on upgarding from the 17x9.5/17x11 combo to 18inch rims. I would like to retain the 315s in the back but the problem is that its hard to find a wheel company that makes a 18x11 inch wheel. Prices for 18 inch tires usually hover avobe the $300 range....I also looked for 315s for 18s and only Pirelli makes that size......the next size up or down is either 295/30/18 or 335/30/18. I think its gonna be a bitch to try and fit 335s in the rear.
Old Sep 17, 2002 | 03:35 PM
pu12en12g's Avatar
Blown makes a good point. I would only consider 18's + if you have a set of track tires mounted on your stock rims. So that way, you can use those at the track. Why would u want to abuse your street tires anyways right ?
I don't hear much talk about this, I assume because most of us don't have a truck to haul the 2nd set of tires etc..etc.. but that really is the way to go.
Old Sep 17, 2002 | 06:19 PM
WhiteDeathLS1's Avatar
I went with 18" x 9.5 on all four corners. The correct tire size is 275/35/18 if you want to keep your speedo on check I hvae pics in the sig...
Old Sep 18, 2002 | 11:34 AM
tubby's Avatar
i went with 18" z06 rims and i get more compliment on that than anything, love em
Old Sep 25, 2002 | 12:20 AM
I agree that the 18's will look better, but what offset am I going to need, I'm assuming that it will be the same for 18's or 17's if they are both 9.5 wide right? Am I going to have to change my jounce bumpers?
Thanks for the help
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
rvonsternberg
Sep 14, 2015 11:58 AM
Daluchman1974
Sep 11, 2015 06:12 AM
scottcba1
Sep 8, 2015 09:52 AM
