*Salad Shooter ?*
Old Dec 29, 2002 | 03:10 PM
PurePonyPounder's Avatar
Question *Salad Shooter ?*
I need to know whether its possible putting on 225 tires on salad shooters. I know some came straight from the factory with 235. Any info would help me out.........Thanks
Johnny
Old Dec 29, 2002 | 03:18 PM
Ernster500's Avatar
The stock size on the 16x8s salad shooters were 245/50-16s.
I think the v-6s and some Zs came with 235/55s.
You could probably check www.tirerack.com and see what the rim width requirement is for a 225 is.
Just out of curiosity, Why would you want to put thinner tires on?
Old Dec 29, 2002 | 05:06 PM
chesee48's Avatar
yea i was wondering that too...
i always say...the bigger the better
unless u already had those tires laying around or got them for a really good deal, then thats understandable...
Old Dec 30, 2002 | 10:26 AM
CeeBee94Z's Avatar
He may want the narrower tires for the winter...that would be my guess...I think 225's might be pushing it, but may work...
....225's are about 8.86 inches wide where 245's are about 9.65 inches wide...when you go too narrow on a rim that could let to problems....on my jeep I have 10.5 inch wide tires on an 8 inch rim and that is too narrow so one time when i was offroading i broke the bead and ended up with a flat...so check specs first
Old Dec 30, 2002 | 10:32 AM
Thank you everyone for your prompt responses. I need to know for two reasons: A. I'm debating on removing my entire power steering set-up (clean up engine bay and not to mention the space I will have to work on my ride) B. Winter is upon us so the narrower the tire the better.
Johnny
Old Dec 30, 2002 | 06:24 PM
ishz28's Avatar
You can go two up and two down. 245/50 is one up, 255 the max size without issues. You can go down to 215 if you like. Most professional tire stores have a tire sizing booklet for each size rim. I don't know if the newer converts come this way, but my 94 Z came with 235/50's, 2.73's and a 108 mph limiter.
LT14LIFE
Nov 15, 2015 06:22 PM
IndyZman
Oct 22, 2015 02:17 PM
Lt1son
Jun 29, 2015 08:23 AM
97znebr
Parts Wanted
Apr 12, 2015 02:31 PM
blac94Z
Wheels and Tires
Apr 7, 2015 12:46 PM
