Will valve stem lash caps increase lift?
Old Sep 16, 2003 | 10:07 PM
MattysTA's Avatar
Question Will valve stem lash caps increase lift?
I was wondering if and how much if any would using lash caps on the valve tips would increase lift. say if you were using 1.6 rockers and the lift on the cam w/rockers is 520 in/ex how much more would lash caps increase the final lift if any. the lash caps are .06" thick. thanks.............
Old Sep 17, 2003 | 05:22 AM
SStrokerAce's Avatar
Nope,
only lobe lift and rocker arm along with the lash setting give you max lift.
Bret
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Roadie
Feb 16, 2015 10:34 AM
Sandersen511
Jan 13, 2015 03:49 PM
TA Jack
Sep 3, 2002 07:52 PM
