White smoke, but no coolant/oil mix....what is it?
Old Oct 19, 2004 | 07:05 PM
BAD 97 WS-6's Avatar
I am thinking worse case here. I am hoping not cracked block. If so, wouldnt the oil and coolant mix. I replaced the head gaskets already, but after 3 days of normal driving, the smoke came back. It does it after the car warms up, then seems to go away when driving, but come back at idle. I did have the heads ported but only the exhaust ports.
Old Oct 19, 2004 | 07:16 PM
Damon's Avatar
Re: White smoke, but no coolant/oil mix....what is it?
The exhaust porting mighta broken through into the water jacket surrounding it or allowed a very slight crack to form in the exhaust port that starts leaking when it gets hot. That would explain steam out the tailpipes but with no oil/water mixing. It would not explain why new head gaskets would make the problem go away for a while then come back.
Good radiator shops can put a "sniffer" on the radiator and determine if exhaust gasses are being detected in the cooling system- a sure sign that something is cracked/leaking somewhere in the combustion area (cylinder head/block bores/head gasket). They can also pressure test it and see if it holds pressure. If not, it's leaking somewhere, although not necessarily in the combustion space.
Old Oct 22, 2004 | 11:00 PM
jcsbadta's Avatar
check your o2's, might have got some rtv or oil on them and they are reading lean. so the ecm is adding fuel and running the engine rich.
i had the same prob. but with a large cam that wouldnt run in closed loop because of the cam overlap. my car smoked white/grey at idle and went away after i reved it up.the o2s read lean ,but the motor was rich.
IndyZman
Oct 22, 2015 02:17 PM
Hal Fisher
Sep 30, 2015 09:03 PM
frankrizz
Sep 23, 2015 04:21 PM
jackpawt883
Sep 10, 2015 08:53 PM
