where can i go to learn about rods?
Old Jan 27, 2003 | 11:24 PM
kandied91z's Avatar
Smile where can i go to learn about rods?
i'd like to know what the different aspects are and how to choose one brand over another. any suggestions?
Old Jan 28, 2003 | 01:42 AM
Lowend's Avatar
I'd say you are in a good neighborhood right now -
did you have any specific questions?
Old Jan 28, 2003 | 02:55 AM
SStrokerAce's Avatar
You beat me too it. I was thinking that when I saw the topic.
We need, application, HP, max RPM, Blower/Turbo/N2O
That kind of stuff.
Bret
Old Jan 28, 2003 | 07:33 PM
kandied91z's Avatar
bret i had told you a while back about what i was doing....here's a brief rundown. still need to measure for the exact so i can't say for sure.
it's a 383 setup pushing at least 500/500 at the crank N/A as well as three power adders looking for an even 600 across the board.
just wondering where i can read up on different ones........i know that even once i know the exact size i need there will be many brands to choose from and other little things so i'd like to have some knowledge going in!
thanks for the replys guys!
Old Jan 28, 2003 | 10:26 PM
Well up to 700hp I would say Eagle H-Beams. $500 a set they will hold alot of abuse.
Then if you want more rod than that, a www.Cat-Pep.com Billet I-Beam for $780 a set sounds good to me.
Old Jan 29, 2003 | 01:39 AM
kandied91z's Avatar
can you recommend some reading for me so i can kind of learn on my own?
Old Jan 29, 2003 | 01:56 AM
I think Hot Rod has a article either this month or last month on Rods, Cranks and Pistons and that should give you the basics.
Other than that....... It's mostly mechanical engineering stuff. Books by David Vizzard, he has a Small Block Chevy Book on Cranks, Rods and Pistons that would help too.
Bret
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
RX Speed Works
Sep 11, 2015 03:31 PM
Daluchman1974
Sep 11, 2015 06:12 AM
