What rings?
Old Oct 29, 2002 | 12:12 PM
  #16
SStrokerAce's Avatar
good question. I will have to ask Total Seal
Old Oct 29, 2002 | 03:34 PM
  #17
drop top steve's Avatar
Originally posted by arnie
Care to elaborate?
Nothing I can prove one way or the other. In my case the engine was down on power from the previous season, 2/10 and 2mph avg. Came back the following season when I went back to the plasma molies.
My blower friends talked of ring flutter or unloading at hi rpm. They tried different tune-ups for about a half season then went back to what they had before, they are 5.80/5.90 cars One was div 6 champ. This was 94/96, they may have changed or improved the gapless ring sets, but I tend to stay with what works for me and I'm just a bracket racer, I don't have to worry about hitting a number, just 200 passes a year without breaking.
Old Oct 29, 2002 | 03:55 PM
  #18
arnie's Avatar
Originally posted by SStrokerAce
The Max Seal top gapless ring is very good.
Keith Dorton worked alot with Total Seal and Mahle to maximize ring seal. Bret
I take it, Max Seal is a competitor of TS, and not one of Total Seal's line of gapless ring.
Old Oct 29, 2002 | 04:08 PM
  #19
nope,
Max Seal is the Total Seal Gapless top ring set.
Bret
Old Oct 29, 2002 | 06:11 PM
  #20
Mindgame's Avatar
And the same story gets told over and over about gapless rings.... "gasses get trapped between the top and 2nd ring, unseating the top ring..... flutter". Yeah, some guys even use pistons with an accumulator groove which is suppose to help.... but why?
Why go through all the trouble when a Speed Pro works so well? I've never seen horsepower figures that'd change my mind the other way either. I don't believe any of the Nascar boys will be giving up their inferior "gapped" rings anytime soon... time will tell.
-Mindgame
Old Oct 29, 2002 | 06:29 PM
  #21
arnie's Avatar
Originally posted by Mindgame
I don't believe any of the Nascar boys will be giving up their inferior "gapped" rings anytime soon... time will tell.-Mindgame
Fortunately for them, the concern over varying chamber temps is not an issue. Such is not the case for those that must deal with varying temps, from being either on, or off boost. What is too 'wide' for one, is just right for the other. What is just right for the former, will be 'butt' city for the latter. Time to stop, B4 I get confused.
Old Nov 3, 2002 | 07:30 PM
  #22
zhevy-1's Avatar
-Mindgame
How do you compare the Speed Pro Rings to the Childs and Albert Rings?
I was considering the TS Gapless Rings, but after reading the reviews here, I have ruled them out.
Now, I'm left with a decision to make here. What's the best available ring for a 383 Stroker 6" rods, 11.5:1 compression N/A LT1?
I have a bent valve, and possibly damage to a piston. Worst case scenario, I'll be buying a replacement piston (JE Pistons) and re-ring the rest. My goal is to do this right. A bad decision this deep into an engine, it's a co$tly one.
I want the best, but I also want to keep it simple if I can help it.
THX-Goose.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
mmf_1013
Sep 12, 2015 08:56 PM
blaze309
Sep 8, 2015 05:27 PM
Catmaigne
Jul 14, 2015 05:17 PM
