versatile shortblock
Old May 1, 2003 | 10:51 PM
abates's Avatar
could a short block be built to run both high compression (11.5 or 12 to 1) & low compression (8.5 or 9 to 1) by simply changing the heads & head gaskets? if so, you could have a cam & heads for boost and a separate setup for higher compression. that would be cool!
Old May 3, 2003 | 06:12 PM
DropZ
Guest
Posts: n/a
I remember reading somewhere that either Saab or Volvo are working on a variable compression 5 cylinder motor. Basically, the head is hinged on one side, and has solenoids/actuators/something that can vary the height on the other side, and flexible gaskets all around. Said they could get a decent range of compressions, from 8:1 to 10:1 or something, all controlled by the ECU based on load/boost/throttle etc.
Also said it looked like a beating heart sitting there running, with the head rocking back and forth. Interesting concept; sorry I don't know deck height and such that would be useful answering your question.
Old May 6, 2003 | 12:01 PM
abates's Avatar
TTT
Old May 6, 2003 | 06:38 PM
LT1 1980 malibu's Avatar
Ah yes and yes..Simply have two different sizes of chambers..My 18* engine has smallish 36CC chambers and aproximately 16-1 compression.Currently im looking into buy some other 18* heads with 48cc chambers and running a .050" head gasket to run the engine on race gas..
Standard SBC heads are usually offered in a 76,72,64,52 cc chamber size..CNC machine work with concave headed valves can help bring up the compression..But unless its a race setup running in two different classes in two different seasons i wouldnt see why one would do such a thing..
karpetcm
Aug 14, 2015 03:02 PM
jackpawt883
Jul 31, 2015 08:15 AM
jrp4uc
34
Oct 15, 2002 11:41 AM
Bando
Aug 2, 2002 02:18 PM
