Velocity Ring
Old Feb 18, 2005 | 03:36 PM
'68LT1camaro's Avatar
Velocity Ring
How effective are these when used on a centrifugal supercharger? Typically, how much more boost can be gained, if any? Any opinions or theory of opperation on velocity rings would be appreciated.
Raymond
Old Feb 18, 2005 | 09:52 PM
ru2slo_99's Avatar
Re: Velocity Ring
We learned in fluid mechanics that the radius helps intake and out flow to a certain extent. If the radius is too long, the helping effect is lost and could hurt flow.
If the thing is actually engineered for the purpose of a supercharger intake, then it should make a few pounds of boost.
Old Feb 19, 2005 | 05:44 PM
ru2slo_99's Avatar
Re: Velocity Ring
This is the only picture I could find.
Old Feb 19, 2005 | 06:06 PM
Zero_to_69's Avatar
Re: Velocity Ring
FYI:
I picked up 4 HP at the wheels by installing a K&N stub stack on my carburetor.
The stub stack is designed to reduce turbulent currents as air enters
the carburetor. It seems the velocity ring may serve a similar purpose.
I'm thinking that device is installed on the mouth of the supercharger tube
inlet?
Old Feb 19, 2005 | 10:31 PM
ru2slo_99's Avatar
Re: Velocity Ring
It needs to go right on the supercharger.
I am wanting to make one for my car, but I dont know about clearence between the block and the supercharger.
Old Feb 21, 2005 | 01:39 PM
Re: Velocity Ring
Has anyone out there ran one of these with a supercharger?
Raymond
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
mmf_1013
Sep 12, 2015 08:56 PM
blaze309
Sep 8, 2015 05:27 PM
Catmaigne
Jul 14, 2015 05:17 PM
