variable camshaft for sbc
Old Feb 11, 2003 | 09:55 PM
  #31
turb0racing's Avatar
So, in a month or so ill start a new thread and inform you guys on the progress. Thanks for all the help OldSStroker and SStrokerAce .
Old Feb 12, 2003 | 10:12 PM
  #32
I changed my mind mow im going with OldSStrokers idea to use oil activation. I will start off with a 2 way solenoid adn a small ~2" round piston. With a 5:1 arm, piston to cam i will only need .75" of stroke of the piston to change form high to low cam. Using a 5:1 arm will accieve 628 lbs pushing the cam i and out. ant thats with only 40 lbs of oil presure and thats more than enough. and i can make the change less noticible and smoth if i put a restrictor in the fill line. Another reason why im using the oil activation is because its way cheaper than electronic control being less than $50 for a general purpose solenoid valve.
How would i activate the solenoid i was thinking of using the rpm reading but what is it measured by with and electronic tach? Is it the incoming volts or a digital signal or other?
Old Feb 13, 2003 | 09:55 AM
  #33
OldSStroker's Avatar
MSD makes ignition devices to actuate electrical things at any rpm. They use plug-in chips which are available in 100 rpm increments. Check their website.
Use a spring to hold cam in one position and actuator to move it to another. It "fails safe" to the baseling position, and only needs a one-way actuator.
Both of these ideas have been done before.
G-BODYT56
Jan 14, 2022 11:14 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
