Valve Lash Cap Question On My 396 Solid Roller
Old Jun 6, 2005 | 09:12 AM
fast 93 z's Avatar
I am converting my 396 LT1 to a solid roller set-up with T&D shaft mount rockers. I hear I should use valve lash caps on top of the valve stems. Is this true? I have the Ferrera Pro-series valves. Should I use the caps to protect the valves or will it be fine without? Thanks
Tony Shepherd
Old Jun 6, 2005 | 12:16 PM
P's Avatar
P
Re: Valve Lash Cap Question On My 396 Solid Roller
Lash caps = more surface area for the rocker to plant on. It's purely up to the operator to run them or not. I do because of more area and it protects the top of the valves as well. Retainers have to be machined for them to work I believe.
I've had no problems in the 7 to 8k miles I put on my motor w/ them.
P
Old Jun 6, 2005 | 02:06 PM
EddieP's Avatar
No reason I can see why you shouldn't put some in (unless you like buying new valves or at least having the tips machined smooth). I had about 7k miles before there was very noticable wear on my ferrera valve tips. Definitely learned my lesson - after having the tips machined smooth, I threw some lash caps in and have had zero problems since. When the caps get beat up and worn, it's a hell of a lot easier to replace them!
Old Jun 6, 2005 | 04:08 PM
1racerdude's Avatar
Tony Shepherd
They are OK but ya will have to check your geometery and get longer pushrod's.
Old Jun 6, 2005 | 04:55 PM
Mindgame's Avatar
I wouldn't worry about running a lash cap unless you just want to do it. You'll need the locks to work with them, so there's a few more things to take into consideration. I'd go ahead and bolt the shafts in with the check fixture and see where everything lies. No sense in having a good setup machined if you don't need to and maybe some caps can help you avoid that. Don't know till you check.
-Mindgame
Old Jun 6, 2005 | 10:43 PM
fast 93 z's Avatar
Thanks for the help guys!
95chwagon
Jan 13, 2015 09:19 PM
Jul 4, 2005 05:00 PM
Wicked
Jul 25, 2002 04:19 PM
Ed95Pont
Jul 23, 2002 08:26 AM
