for those that have converted to fuel rails...couple of questions
Old Dec 12, 2004 | 01:37 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
Question for those that have converted to fuel rails...couple of questions
well i will be converting to non oem fuel rails,
first question, i figured i would ask before i hooked battery up, got a gas can and turned the keyto verify. which of the stock lines going to the intake is the feed line.is it the bigger one or smaller one?
second question. the small module on the passenger side of the intake.... that currently has the vacuum line going into it...do i need to keep this or not? i heard it isn't required to be hooked up.
also the vacuum hose that comes out of it goes to a y vacuum fitting. wtf are those lines for...can i just eliminate that $hit. i don't have HVAC system in the car anymore.
thanks alot for the feedback guys...in advance of course
Old Dec 12, 2004 | 03:25 PM
Z284thgen's Avatar
Re: for those that have converted to fuel rails...couple of questions
if memory serves me correct the larger one is the feeder and the smaller is return
also the module is for the evap canister mines unhooked and gone of my car
it also has a vac line going to the fuel lines as well as the TB.
now the vac lines that goes into the y fittin might be the ones for the HVAC system
not sure on the 96's
is this the stuff you talking about
http://shbox.com/1/1996_evap.jpg
Old Dec 12, 2004 | 07:23 PM
taner's Avatar
what is it like on your car. i understand that the small line, being the thrid line for the fuel sustem goes into that module, i am just going to disconnect it from under the car and cap it off.
hmm i am running the monoblade, and i don't recall if i have a vacuum line running into the t.b. lol!!! how pathetic! let me run and take a look.......brb........ok, no lines to the throttle body, i didn't think there were.
back to the white y fitting for the vacuum lines. actually one line comes out of the harness lead into the trans tunnel, the second one heads into the wire harness that goes toward the battery.
where is our charcoal cannister in our cars is it under the battery?
thanks
taner.
Old Dec 12, 2004 | 09:01 PM
Z284thgen's Avatar
thanks
taner.
charcoal canister is located just behind the filler neck in the rear qtr panel to access it you have to pull the filler neck plastic thingy off and also the rear inner fender liner evap system
i pulled the module and lines off and capped everything as well but mine is a lil different then yours mines missing #7,5, and 1
HVAC vac lines
HVAC vac tank location 1995
everything i bet is pretty close to the same location on your 96
Old Dec 12, 2004 | 09:26 PM
taner's Avatar
awesome i am gonna run back outide and take a look....brb i have pulled #5, and will pull #7 and #1 too.
i still have the check valve and vacuum canister..i want to pull those as well. is it ok to? have to look for the charcoal cannister
Old Dec 12, 2004 | 09:31 PM
Z284thgen's Avatar
yeah it wont hurt to pull the canister and check valve if you have no HVAC system. but this y-fitting your talking about going into the tranny tunnel is got me wondering where it could go to.?
Old Dec 12, 2004 | 09:44 PM
taner's Avatar
do you know what i mean about the y vacuum pipe??? it comes off of the check valve(bout 6 inches from it), it is the vacuum line that goes towards the back of motor/intake, for lack of a better description. i would guess it goes either to the fuel tank or cannister? just an unedumacated guess
also of topic....do you think i really need to keep the vented lines to the opti? hell unvented optis do just fine, and the car is driven alot, but mostly in good weather. the more crap i can do away with the better
thanks alot for the links!!!!!!!! they rock!
Old Dec 12, 2004 | 09:49 PM
Z284thgen's Avatar
try to track that thang down as far as you can.
mine came from the check valve 1 to the inside of car 1 to the vac canister below car by the horns and the 3rd one went into the harness and came out and hooked up to the intake right by the one for the FPR
Old Dec 12, 2004 | 09:50 PM
Z284thgen's Avatar
also the vents for the opti i would just leave hooked up your talking maybe no more then ounces
Old Dec 12, 2004 | 10:02 PM
taner's Avatar
not so much weight just 2 less lines in that area, i already have all the nitrous wiring and msd wiring running in that vicinity is all. and with the Hogan intake going on, well the less in the way the better
thanks for all the help. i will trace that line later this week and post back, not going outside now, lol! time for bed!
g'nite!
RiverMutant96
Jan 30, 2015 09:21 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
guionM
9
Aug 29, 2002 01:48 PM
