TFS heads with LT4 intake?
Old Oct 5, 2005 | 10:35 AM
Randy Molkentine's Avatar
Do they bolt together with no problems? Or is any machining required since the head is LT1 based. Thanks,
Randy
Old Oct 5, 2005 | 06:09 PM
Denny McLain's Avatar
Re: TFS heads with LT4 intake?
Randy
Not really advanced tech but to answer your question, the heads are designed for the current LTx engine and it doesn't matter if it's a LT1 or a LT4 intake. Pick your color.
I'd recommend you have the TF heads ported or instead have your existing heads ported. Mine as cast only flowed 260/177 @ .600 which is easily beat by your average LT1 port job.
Old Oct 5, 2005 | 09:51 PM
I already had Lloyd work them to 295/230. I was just wondering because the LT4 intake requires LT4 heads and these work with a LT1 intake. I know its not to advanced but I dont think many LT1's are running TFS heads yet. I only went to the TFS heads because of their thicker deck and lower compression as they are going on a D1 charged 383. Also they are not that much more then nice full port LT1 heads. Those go for what $1800-2000. I got my TFS heads for less then $900 then put $400 more into porting and $700 for nice beehive springs, bigger valves, Ti locks etc. So thats $2000 then I sold my LT1 heads for 150, bringing my total investment to 1850. $1850 for thicker heads with more material that flow more then the best LT1 casting ever would, AND they are nice and shiney .
LeftoverChinese
Jan 14, 2024 03:03 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
